Question about Maytag MBF1956HEQ / MBF1956HEW / MBF1956HEB Bottom Freezer Refrigerator
Freezer working but fridge is getting warm. I think that the freezer door was open a little. Will I need to defrost it to get the fridge working right?
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
Master_Tech
  • 770 Answers
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Posted on Feb 22, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Posted on Jun 01, 2008
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
Defrosting issue or need to replace refrigerator?
If your refrigerator was manufactured in 1999, it is way overdue for replacement.
Apr 05, 2017 | Magic Chef CTF2125 Top Freezer...
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Only the freezer side is working
I don't think the darkness is related to the fridge not being cool. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Fridge not cooling
your defroster seems to be out. This is located in the space between your freezer and fridge where your temp. control is. This defroster can be purchased at an appliance parts supply take model number and serial number with you in order to get the correct part. Once part is obtained follow instructions and unplugg unit before servicingf
Jul 13, 2009 | KitchenAid KSCS25FKSS Side by Side...
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator warm, freezer too cold
  • possible causes:
Jul 06, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag MBF1956HEQ / MBF1956HEW / MBF1956HEB Bottom Freezer Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
