Question about Zenith H32G48S TV
Got an older zenith TV that is locked on channel 3 and can't get it unlocked for channel 4 for my cable box, Took it to a repair shop and and they couldn't figure it out. I don't have the origianl remote control Zenith TV serial number 42203040022/ model number H2520Y
  • nikipetersen Jul 08, 2010
    The previous suggestion didn't work. TV locked on channel 3 and I need to change it to channel 4 for cable.
  • 10,865 Answers
Hi. You could purchase a universal remote, or you could just check craig's list or estate sales because the analog sets are worth almost nothing now that digital is in and so popular. You should be able to get a great used analog set for $10 or $20 dollars. J.
Posted on Jul 08, 2010
  • nikipetersen Jul 11, 2010
    i have already purchased 2 different universal remotes. Also the TV repair store tried every Zenith remote they had in the store and none of them worked.
  • Zenith Master
  • 6,993 Answers
I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlock the auto-program (change to 0)
This might reset the code.
Good luck
    This was attempted by the repair shop tech and didn't work
Bought a used tv with remote and the channels are locked, how do I unlock so I can get all the channels?it is a Zenith TV.
on the remote,press cable once,then press& hold setup until the cable key blinks twice, then release setup,enter 9-7-3,press CH once, the cable key will blink four times......done .......hope that helps
Feb 18, 2010 | Televison & Video
I just hooked up cable and dont have a remote for my older tv how do I get to ch 3??
Good day,
Look on the back of the tv to see if you have a channel 3 4 selector.
If so, set it to 3.
If your tv has basic controls on the front, such as on/off, volume and channel select, remove your cable hookup to the tv, turn on the set, and using the channel controls set it to channel 3.
Reconnect.
Feb 08, 2010 | Zenith Z25A11S 25" TV
How to connect a 1999 zenith TV to a cable box and
Connet the output of the cable box to the DVD player and the TV out output of the DVD player to the TV (TV must be tuned to Channel 0, Chanel 3 or 4). You should be able to use the remote to switch between the DVD signal and the cable signal.
Hope it helps.
Sep 08, 2009 | Zenith A25A23W 25" TV
Can't auto program Zenith TV for cable channels
  1. Did you try to call LG/Zenith customer support and see if they can help you? If not find your nearest LG/Zenith service center (not Best Buy) preferably a small service shop to see if they have a service remote to unlock it
Aug 23, 2009 | Zenith Z37LZ5D 37 in. LCD TV
How to change vcr input from channel 4 to channel 3
On the Zenith, turn the power off. Hold down the Channel up or down button on the machine itself (not the remote) for 5 seconds, it will say RF03 hold down until it says RF04.
Apr 27, 2009 | Zenith XBV243 DVD Player/VCR
I cannot get my tv to turn on channel 3 so it will work with the cable box
does cable box have a switch that you can change to ch 4? if cable box does, and tv can switch to ch 4, use ch 4.
Apr 04, 2009 | Zenith Televison & Video
Cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 27, 2009 | Zenith B27A11Z 27" TV
Up and down arrows on channel or menu selections not working.
All the functions of in putting and selections channel are done by one stage of a tv. take your tv to a w/shop, it wll require change of components,
get a diagram from
www.universal.remote.net/zenith.html
further help will be provided
Dec 06, 2008 | Zenith B25A02Z TV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Zenith H32G48S TV Logo
53 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
