Hi There, I have a Samsung SMC142 which I use for the security cameras around my home. It has four channels which connects to the 4 respective cameras. We had a power outage and when it was restored, the monitor remained blank. The power light is "Red" but the screen is blank. Any thoughts as to what has happened? Cheers, Sal
  • sala1200 Jul 08, 2010
    Thanks for the very detailed solution. I'll try myself first but if all else fails I'll get my electrician in. Again... MANY THANKS!!
    President:
  • 1,099 Answers
HI
I hope I can help you with your issue,
First , you open the back cover of the television to check for dry soldering, if found resolder, but if otherwise
Either the power supply has an issue , or you have a bad buffer board and Ysus scan board or both.red light indicating may mean power supply , 7 blinks the buffers and y board.
A repairman will usually just order the boards and you will spend about $550-$600 on the power supply or over $700 probably around $850 if its the Y board and buffers.
It could be just a few bad capacitors on the Power Supply, there could be a bad capacitor on the Y board if its bad it needs to be replaced with the buffers together
If you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
The ones you are looking for are located almost center bottom of the power board,Usually I can see them clearly with the back on simply shining a light into the back through the holes
With the back removed you will see a few circuit boards the upper one (ac cord runs to it through a small board) is the power supply, it has alot of capacitors on it (cylindrical standing straight up soldered in and marked on the sides with the positive/negative sides and uf and Volts values)
Philips uses 2200uf or 3300uf at 35Volts rating capacitors, they cost about $1-$2 each
The power board and back unscrew with a torx bit and screwdriver size 10 and 15 , if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
You can replace the whole power supply, but samsung has a few versions in their sets and some so called replacements won't fit due to cable location (sockets) being in a different spot.
If there is a blinking red light on the TV count the blinks,if it still blinks after replacing the swollen cap this would indicate a bad buffer board ,
check the capacitors by looking for the swollen tops I hope thats all it is (usually is), if there are no bad caps , then Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck....
Posted on Jul 08, 2010
No picture,circle with slash
This means that there is no camera signal getting to the DVR. Could be a bad camera, or camera power supplies, or connection to DVR or camera.
Feb 13, 2013 | Samsung SDE-120n 4 Channel DVR System
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
Tring to connect my samsung tv to my samsung home cinema and having problems
Hi,here is my simple solution...
to listen your TV on your Stereo system thru your
samsung home cinema receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
samsung home cinema RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the
samsung home cinema Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Samsung Audio Players & Recorders
We purchased a home with 4 samsung cameras in various places around the exterior. They are all wired back to the master bedroom with what looks to be CAt-5 cable. What do I need to make this system work??...
Hi there, depend on the model of your cameras, normally if there are samsung it should say the model # ( ssc-12c,soc-c120 and so on) What look like CAT-5 are normally RJ-11 very similar to a phone connector. If your cameras are one those mentioned above you will need a monitor that support that type of connection like the ssc12m or ssc-17webm if there are black and white or the SMT-190M if there are color cameras. or a DVR with similar connection type like the SHR-1041.
Thank You,
nationalprosecurity.com
Oct 17, 2010 | Samsung Weather Resistant Security Camera...
Hi, Ive tried to set up my samsung blue ray
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Oct 26, 2009 | Samsung Audio Players & Recorders
Im looking to download the software for this machine
would like to view my home from iphone i have a samsung shr 2040 dvr
Aug 08, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
I have two samsung ssc-12c cameras.
green wire : 12v dc
clear wire : video ( + )
wire around clear wire : video and 12 vlt ground ( - )
you don't used the rest of wires . rest are audio .
Nov 20, 2007 | Samsung Weather Resistant Security Camera...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
