Question about Refrigerators
I do not want the small blue light to be on, but cant figure out how to turn it off or how to take the box with the manual control & the light off the top right hand corner of the smaoll fridge.
  • 6,993 Answers
what's the model and make of your small fridge?
I would advice that you check the manual, it should have a solution to this problem.
Bye for now.
Posted on Jul 08, 2010
  • danf518 Jul 08, 2010
    Model number galaxy model 183-91772. I cannot find the manual at home or on the web. It's a small refrigerater.
1996 grand cherakee.Fuse Panel diagram
Good lord there are fuses everywhere in that truck if I remember right, you'd have been better off asking about the problem I think.. try here
http://www.jeep4x4center.com/knowledge-base/index.htm#service
find your truck, pull up the PDF then on your keyboard hit the find box (F3?) punch in "fuse" and run down the list...
For the basic panel
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): CAVITY FUSE DESCRIPTION 1 10 amp (RED) Radio 2 15 amp (Lt Blue) Cigarette Lighter 3 10 amp (RED) Rear Washer Switch, Body Controller 4 10 amp (RED) Airbag 5 10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 20 amp (Yellow) Body Amp, Cluster, Body Controller 8 20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 15 amp (Lt Blue) Brake Switch 10 10 amp (RED) Rear Window Defroster 11 10 amp (RED) ABS Module 12 10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 15 amp (Lt Blue) Spare 15 15 amp (Lt Blue) Spare 16 10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 20 amp (Yellow) Spare 19 15 amp (Lt Blue) Passing Light 20 15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 15 amp (Lt Blue) Power Outlet 22 10 amp (Blue) Airbag Module Turn signals are in the flasher and it is located on the driver side below the dash (where the buzzer is located). It is a cylinder type relay. You will find two, one for the hazzard lights and the other for the signals.
Sep 19, 2014 | 1996 Jeep Grand Cherokee
I have no tail lights on my 1992 subaru svx wheres the 10 amp fuse located
the fuse box should be under the steering column inside the lower dash. there usually is a small cover to mark its location
Nov 10, 2013 | 1992 Subaru SVX
What color is the rca cord to whire up a amp in a 1999 vt commodore?
i just took wires out of a car that used to have a amplifier and they where one small light blue and one black i dont know if that helps any
Feb 16, 2013 | 1998 Holden VT Commodore
2000 Town and Country. Blower motor, turn signals and power seats quit. all at once. cant figure out where to check.
the culprit is fuse f12 -a 10 amp fuse on the right end of the small fuse panel by below the hood release under the dash. I had same problem - something is blowing the fuse; in my case it was something in the backup light circuit. This fuse is the power source for the relay coils that power all the other circuits that stopped working.
Feb 05, 2012 | 2000 Chrysler Town & Country
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
Lost owners manual and was testing fuses at the junction box. do you have any info. as to what each fuse controls. i lost my dash controls ex. speedometer oil guage . its 1999 jeep cherokee ltd
Here is the diagram you were looking for, hope this helps :)
Cavity Fuse Color Description F1 -- -- Spare F2 -- -- Spare F3 10 Amp Red Headlight high beam left F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094) (Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier F6 15 Amp Lt. Blue Park lamps F7 10 Amp Red Interior lights F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks F9 20 Amp Yellow Power outlets F10 20 Amp Yellow Adjustable pedals (2002-2004 only) F11 10 Amp Red Rear window defrost indicator F12 10 Amp Red Auto shutdown relay / "Fuel" F13 -- -- Spare F14 10 Amp Red Headlight low, left F15 10 Amp Red Headlight low, right F16 10 Amp Red Headlight high, right F17 10 Amp Red Instrument cluster, diagnostic connector F18 30 Amp ? Trailer tow F19 10 Amp Red Anti-lock brakes F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center) F22 10 Amp Red Ignition Run / Start F23 15 Amp Lt. Blue Brake switch F24 15 Amp Lt. Blue Foglamps F25 20 Amp Yellow Accessory delay relay (sunroof) F26 15 Amp Lt. Blue Cigar F27 15 Amp Lt. Blue Rear fog (export) F28 10 Amp Red Body Control Module, Acc/Run F29 10 Amp Red Rear wiper switch. Washer motors F30 15 Amp Lt. Blue Radio F31 10 Amp Red Ignition Start F32 10 Amp Red Ignition Run / Start - Airbag F33 10 Amp Red Ignition Run / Only - Airbag C1 20 Amp Yellow Wiper (Circuit Breaker) C2 20 Amp Yellow Seats (Circuit Breaker) C3 -- -- Spare
May 16, 2011 | 1999 Jeep Cherokee 4WD
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
you'll need a small 12 v lamp to figure out which one has the power terminals. after mapping that out you need to find a small battery and hook it up to a pair of wires to figure out to which speaker the wires go to.
note : new car radios don't use the chassis ground as common (negative).. the head unit has a negative and positive wire for EACH speaker.
Mar 13, 2008 | Pioneer DEH-P6800MP CD Player
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
