Question about Continental Electric Portable Air Conditioner
Can a portable air conditioner be plug to a portable battery source?
    Problem Solver:
  • 18 Answers
NO.....that would be DC voltage and this unit probly needs A/C voltage. However a genarator would be just fine if it produced enuff watts.
Posted on Jul 08, 2010
  • americanbull May 27, 2011
    if this portable ac is plugged with a power inverter, can it be plugged in a car? with two 12volt batteries let s say 40amp each gel type battery? As i have an old van and a portable ac and the batteries...so all i have to do is to buy the inverter just in case it works, do you think it can be done?
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
What does E1 mean when it is showing up on a Homewell Portable Air conditioner?
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Feb 27, 2011 | Haier HPR09XH7 Portable Air Conditioner
My danby portable air conditioner won't turn on
New or used? Is is plugged in? Is there electric at the plug? Plug a light in there and make sure it works as a test. Next, check the water pan to make sure it is not full of water. There is a switch there that could be causing the problem.
Jul 06, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
Cooling
Is the fan blowing. If so your compressor is probably the source. If the fan isn't blowing you might have a bad fan motor
Jun 10, 2008 | Maytag M6P09S2ACOM Air Conditioner
Danby portable air conditioner
Look into the owners manuals for that problem code. Have you tried to plug it into a different electrical outlet? Problems with P codes general are a power related. Thanks
Aug 09, 2007 | Danby DPAC9030 Air Conditioner
Continental Electric Portable Air Conditioner Logo
65 people viewed this question
Top Continental Heating & Cooling Experts
Shawn DuRee
Tim Whalen
Donni Steen
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
