Question about Braun Syncro 7526 Electric Shaver
BRAUN SHAVER MOD 7570, SHAVER NO LONGER SHAVES WELL, SHAVER MAKES A LOUD NOISE IT IS SAID I NEED A NEW MOTOR , I CAN'T FIND OUT HOW TO REPLACE IT, HOPE YOU CAN HELP.
  • Braun Master
  • 1,610 Answers
You will find the replacement at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
Posted on Jul 08, 2010
Braun series 7 has a very loud and grating noise. What could be causing it?
If you run the shaver with the shaving head off and it still makes the noise, it is probably the oscillator in the motor that is broken. If this is the case, you can purchase this component from shaveroutlet.com
Braun Pulsonic and Series 7 Motor Drive Unit
Dec 09, 2016 | Braun Health & Beauty
I have a Braun 7570 and it is marvelous! I replace foil and cutter every year. This time after replacing it the shaver did not cut my hair. Battery still gets full charge. What is the problem?
Most likely, the 'drive unit' is bad. The drive unit is a component that consists of the swivel frame that the head snaps onto and the motor. Excessive noise while the shaver is running is also a major sign that this part is bad.
Unfortunately, Braun no longer provides these type of replacement parts for any of their shavers. You may end up needing to replace the unit.
Since you apparently like that model and you have spare shaver heads for it, you might want to consider a compatible model as a replacement. shaveroutlet.com has a new model that uses the same foils and cutters as your 7570. You can see it at the link below
http://shaveroutlet.com/shavers/foil-shavers/braun-series-1-195s-mens-cordless-shaver.html
Feb 19, 2014 | Braun Syncro 7570 Electric Shaver
When I power on to the first setting(shave head pivots) it makes a very loud noise like the insides are loose. On the second setting(pivoting head locked) it gets quite a bit quieter. and if I hold my...
You will find a video for disassembly of the shaver at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
However, I seriously doubt that tightening anything is the problem. More that likely, the oscillator inside the swivel frame is cracked and causing the sound. You will probably need to replace the drive unit. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-motor-drive-unit-p-110.html
May 24, 2011 | Braun Syncro 7526 Electric Shaver
During shaving the shaver makes a loud grating noise. It works fine otherwise. Even during the cleaning cycle, there is a bit more of that noise. Could it need a new battery?
Most likely, the noise is caused by vibration of a broken piece of plastic in the swivel fframe. If this is the case, the part required to fix it for model 8585 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
You will also find an instructional video for disassembly at the link below
Dec 09, 2010 | Braun 8585 Electric Shaver
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
My power cord has broken at the tip. Can I
Braun Syncro 7570 power cord is Braun 7030458 adapter charger cord.
Feb 08, 2010 | Braun Syncro 7570 Electric Shaver
My Braun 7570 has suddenly stopped working, but there is a high pitched whine when I switch it on.
This sounds like a battery problem. The likely remedy is to replace them. You will find batteries for your shaver at shaveroutlet.com
Jan 17, 2010 | Braun Syncro 7570 Electric Shaver
Looking for a service manual for the Braun 7570 syncro razer
It's actually easier than it looks. On the bottom of the shaver is the charging port. That black plastic piece surrounding it can be pried off. Do it carefully, so you don't dent/scratch the casing. Once removed, the side pieces easily remove. You'll now see screws holding the body together. Have at it. :-)
Jan 08, 2010 | Braun Syncro 7570 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
221 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
