Question about Kodak EasyShare One Digital Camera
Batteries go dead when trying to download pictures to my computer
  • 3,083 Answers
Transferring pictures takes a huge chunk of electricity out of the batteries. The solution to this, is to use a memory card reader to download the pics. That way, you don't have to use the camera's batteries up downloading.
Posted on Jul 07, 2010
Cant transfer pics. to computer screen
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 28, 2012 | Kodak C195 Digital Camera
Battery exhasted when trying to download pictures
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Connecting the L20 to the computer doesn't charge the batteries; in fact it drains the batteries even faster.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Jan 03, 2011 | Nikon COOLPIX L20 Digital Camera
The camera was plugged to computer and downloaded photos. I left the camera plugged in and batteries went dead. Now camera won't turn on.
Hindsight is a wonderful thing and it is not a good idea to download from camera to pc using batteries because if the batteries go dead you can lose all your images. If you download again put new batteries in first or better still put the memory card straight into a pc or a printer and view and print from the card, or if possible fine out if you can buy a mains lead for your type of camera.Try reformating your card either through a card reader or from the camera with FRESH batteries and it should work again.The file/directory structure was probably corrupted when the camera was trying to work with dying batteries. Let me know if this helps
Oct 07, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Cannot transfer pictures
Ensure that the camera has Date set in the camera setup. If the batteries went dead, you might only have the default date and for some reason this stops the transfer. Obscure but true.
Sep 03, 2009 | Kodak EasyShare C633 Digital Camera
Are you able to download pictures from a camera to the PC if your batteries are dead?
In order for you to download pictures from a camera there should be power on meaning it should be power on , so if the battery is dead the camera is off , that way you wont be able to transfer pictures from camera to computer. But if you have a card reader just put the memory card of the camera to it and you can transfer pictures that way...
Feb 02, 2009 | Cameras
Camera turns off after reviewing two pictures
I suspect this a battery problem which has been described by many Sony users. The camera reads the battery charge wrong
and shut downs down.
For what its worth I had this same problem with both rechargeables and alkcalines. Fresh batteries were rejected after just a few shots and were clearly NOT dead. Solution seems to be either use Sony's NP-NH25 cybershot battery which is made of two AA batteries jointed at the hip or use generic rechargeable NiMh batteries with a capacity superior to Sony's battery (>2500mAh).
Dan
Dec 10, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Camera shows there are no pictures
The type of memory in the pix micro is called volatile RAM. Unlike flash memory that you find in thumb drives that do not require a charge to store data the volatile RAM needs a charge to hold anything. If you left the pictures on the camera the memory will be pulling a charge from the batteries constantly until the pictures are downloaded to your computer and then removed from the camera or until the battery dies or is removed. Replace the battery with a new and it should be fine. Just be sure you download the pictures to your computer and then delete them from the camera to maintain good battery life.
Also make sure you install the software on your computer before connecting the camera.
Aug 05, 2008 | Disney Pix Micro Digital Camera
Batteries run down very quickly
Are you using good quallty Nickel Metal Halyde rechargable batteries? Digital cameras are real battery eaters and do best with NiMH batteries. Try 2200MA or stronger and see if that doesn't make a difference.
Mar 27, 2007 | Kodak EasyShare CX7300 Digital Camera
Kodak EasyShare One Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
