Question about Kenmore Elite HE4 Electric Dryer
Installing control panel for Kenmore dryer 11084821300
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer light comes on but control panel not operating
Your thermal-fuse is located on the back side of the bulkhead upper right hand cornerb68bc9a.jpg
Electrolux family of dryers newer models Dryer Service manual
I have repair photos and more HERE
Posted on Jun 15, 2010
  • 19 Answers
SOURCE: Kenmore Dryer 110.61066000 control panel is on, but just gives a
2 options.
1. your belt broke and the microswitch on the idler pulley is not being depressed therefor the motor will get power. This is easy to diagnose. Open the door and try turning the drum by hand. If it spins with little to no resistance then you need a new belt. If it spins but has resistance then you don't.
2. The motor relay on the control board is bad. The control will run through diagnostics and can appear fine even if this relay is bad.
Posted on Nov 16, 2012
Replacing start switch on kenmore dryer
If you order the new Switch from sears parts direct.... Then when you replace the switch, make sure you unplug the dryer before you take the front panel off. Replacing the switch is quite easy... 4 screws total.
Jul 17, 2014 | Kenmore Dryers
Belt replacement on Kenmore Dryer.
The first thing I do is remove the top. Then I drop the splashplate and remove the controls. If this is the first time you have messed with it their are some zipties that need to be removed. then the controls unplug and the control panel is set aside. The drum is real heavy. If you are 10 feet tall Tarzan you might can get it out by using the belt to assist you after you have removed the idler. A trick is just remove the 3 screws to the rear drum bearing and get the drum out. Then re-attach it to the drum before you install the drum back in the dryer.
Assorted dryer service manuals and more
Aug 30, 2012 | Kenmore Dryers
How do i get the control lock button to turn off?
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Dryer will not turn on. Checked fuse box. its ok. unplugged and replugged. Still no power to the control panel. Is there a fuse behind the control panel?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Jun 15, 2010 | Dryers
Dryer control panel wont light up and told I need a new panel
You can buy the control board yourself for about $200 and install it yourself. It could be a fuse inside that had blown too, Email me at buffalonymann@yahoo.com if you have any questions
Aug 31, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Feb 28, 2008 | Dryers
Dryer won;t work
Remove the top cover and take a hair-dryer to the PC boards on the back of the main control panel.. (3 screws take the top cover off from the back) Mine has done it a total of 5 times now.. what it needs is all new buttons installed.. or a new control panel if this works..
Feb 22, 2008 | Kenmore 82822 Electric Dryer
Kenmore Elite HE4 Gas Dryer-triple beep
Did you have any lights at all on the panel? I just took off the User Interface as going through the troubleshooting guide I found underneath the control panel led me to that solution.
Feb 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
