Question about Garmin nuvi 260W GPS Receiver
Can not get voice comands
How can i reset the system to give voice directions? the volume is set to 100%, and can not get voice comands
    President:
  • 1,111 Answers
If you mean like "turn right on Madison" as an example, you must have the tts voice selected ...that is the computer generated voices...it will not work with human voices....
go in the system setting and go to the voice option, and see if you have any TTS voices...if not, they may have been deleted..if so, go HERE and download the web updater and 1st see if there are any updates, then after that it will give you an option to add voices...just select one or some that are TTS...after there loaded to your gps, go back in the voice option and change it to one of the TTS voices.
if you mean you have no sound at all, post back and i will help you further.
bill
Posted on Jul 09, 2010
My garmin will not talk to me. I have the volume at 100%
get the Garmin Express program: Garmin Express
watch this video:
Then go to tools and find the voices portion. choose your language, install at the bottom and then check to make sure your Garmin has a voice chosen. if it does ... check to see if the device beeps and that mute is off. and if it does not even beep then you must have a bad speaker
Oct 12, 2014 | Garmin nuvi 42LM - GPS receiver
Karbonn a90 pattern lock
Karbonn A90 hard reset 1. Charge the battery 100%. 2. Turn off your KArbonn Andorid phone. Turn ON the device by pressing and holding the VOLUME UP key and the power key together until the phone shortly vibrates. 3. When Android system recovery menu appears, release VOLUME key. 4. Highlight wipe data/Factory reset using volume key. 5. Confirm with Power or Cancel using BACK key. 6. After hard reset is done, highlight reboot system now and confirm your selection. Note! All data will be deleted!
May 17, 2014 | ACCPAC Fax/Voice/Mobileserve for PC
THX navigation system in 2007 Lincoln MKX
Could be mute controls for the telephone. The voice for the Navigation is adjusted separately from the radio volume. If any work was done on the vehicle, like a battery disconnect, then radio controls may need to be reset.
You need to toggle through the Menu to things like screen brightness for the Navigation.
You also have a speed sensitive radio and the volume controls could be affected by these settings.
Jan 27, 2012 | Cars & Trucks
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
I have a nuvi 205 and it has quit giving voice commands. The volume is at 100% but there is no sound
Hello :
You have a software problem with your NUVI . I recommend you to reset [ restoring default factory settings ] your NUVI . That should fix the problem .
good luck .
please rate !
Apr 14, 2010 | Garmin nuvi 205 GPS Receiver
My Garmin street pilot c550 has lost its voice, how do I get it back.
I am going to make some assumptions here. First, that the unit was working properly, giving voice directions, and now is not doing so. Second, that the volume wheel on the right side of the unit is set all the way up and you are not hearing any voice directions.
If those assumptions are correct, when you turn the unit on, press the wrench button at the bottom of the screen. Next, press the down arrow on the bottom right of the screen. Now press the "Volume" button. Make sure "Navigation" is at the level you desire (100% works well for me).
Again from the main screen, press the button marked "Locale." Next to the lip icon, make sure the correct voice (whichever you desire) is selected.
If this does not help, try resetting the unit. Remove the faceplate (there is an indentation under the top) and press the reset button on the right side of the unit. If this does not work, you can try a Master Reset, but be aware: IT WILL ERASE ALL OF YOUR FAVORITES. To do a Master Reset, press and hold the bottom right of the screen while pressing the power button. Release both buttons when the unit resets. Let me know if this helps.
Feb 23, 2010 | Garmin StreetPilot c550 GPS Receiver
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
Audio directions
You must ensure that your volume is not on mute. You need to tap on where the words are, not on the map, until the volume slide bar pops up. You may have to tap in different places until it does. If your volume is set normally, you need to check on which voice you have picked. It's under the options. Pick a different voice and test out the directions.
Aug 09, 2008 | Tomtom GO 910 GPS Receiver
Zumo 550
there is an extra audio menu under the wrench symbol, this one differs from the front panel set both of these to 100%, should be better!
Jun 02, 2008 | Garmin zumo 550 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
388 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
