Question about Haier Mechanical Air Conditioner HWF05XC7
My new Haier AC is icing up
What can I do to stop my Haier from icing up? I never see water dripping from the outside. I hear water dripping around iside the unit and I wonder if it is draining. What goes on? and how can I stop it from icing up?
    Problem Solver:
  • 18 Answers
It either needs a good cleaning on the coils and filter or it low on freon.
Posted on Jul 08, 2010
We got a new Haier AC 8000btu window unit runs on 110plug in used 1summer an2months now new from Wal-Mart was working great now it's misting in water an drips are building up on the bottom inside help
there will be a drain hole on the outside bottom part of air conditioner to drain the condensation out of the device. It might be a hose or a small pipe suggest checking it for blockage .
Jul 20, 2016 | Haier Heating & Cooling
Ice maker is leaking water at the rear of the ice maker, somewhere around the water inlet. Water is dripping slowly and building up an ice ***** BEHIND (outside) the ice cube storage bin AND inside the...
Hello,The reason all the ice freezes together and you see icecicles forming from the icemaker,is going to caused by the water inlet valve on the back of the refrig.is not fully closing but instead it's seeping water through it and dripping into the ice storage bucket. To stop that from happening the water inlet valve would need to be replaced.
On refrigerators that have a built in water filter,alot of times their will be 2 water valves and the one that is bad causing water to seep through it will be the one called the SECONDARY valve.
GENE
Sep 30, 2011 | Maytag MSD2454G Side by Side Refrigerator
It sounds like their is water in the blades and its not cooling my room
Tip the AC slightly downward on the outside so that the water can drip outside. If should be a hole for the water to drip away, make sure it's not blocked. Close your windows and doors. As long as cool air is coming out of the AC, it's working.
Jul 27, 2011 | Haier HWF05XC7 Thru-Wall/Window Air...
My Haier window ac unit is dripping a lot of water into my room. It only starts to do it after it has been on for 20-30 minutes, but comes out in a steady stream from the bottom of the unit for the rest...
The window unit is most likely not tilted towards the outside so that the condensate (water) can flow to the drains on the outside part of the unit. Try leveling the A/C or even tilting (Slightly) towards the outside. This will cure your problem.
If this does not cure the problem then you will have to remove the a/c from the window/wall and remove the cover. Inside you will see the drip pan in the bottom and will have to clean the water channels the run from the pan to the outside part of the unit, they will be clogged with dirt or debris and not letting the water flow properly.
Hope this helps.
Jun 13, 2011 | Haier HWR06XC7 Air Conditioner
Water not draining out of ac it is spraying instead of dripping
If it is spraying against the condenser (outside coil) that is what it is suppose to do.
The ring around the fan is called a "Slinger" ring. Picks up the water and slings it against the condenser helping to cool it down. This makes it more efficient.
May 14, 2011 | Haier Heating & Cooling
Water accumulation and ice buildup
There is already a hole just remove the ac unit from the window,and it`s shell,take it outside and use a water hose to clean it out,and remove anything on the inside that may stop up the drain hole.This needs to be done every year before spring or summer.If this was at all helpful,please rate,thank you.
Jul 12, 2010 | Samsung AW0891M Air Conditioner
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
Haier AC HWR10xc6
Haier Air Conditioners do not have a drain hole or hose like most A/Cs. This problem can easily be solved by carefully drililng about an 1/8 or 1/4 inch hole in the bottom outside edge directly on the metal frame, around the cooling fins.... This will elt the water drain out...if you when outside and looked in while it was spitting you would see the water pooling up in there. Haier expects us to mount these units at an ungodly angle to drain the water, but drilling a small hole will help (really anywhere in that bottom plate would work since the whole bottom is a "drain pan"
Aug 30, 2008 | Haier hwr10xc6 Air Conditioner
Haier Mechanical Air Conditioner HWF05XC7 Logo
257 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
