Question about Amcor MF8000E Air Conditioner
Leaking, can't figure out how to drain it
We bought the unit as "open box" with NO manual. Can't figure out how to drain the water which leaks out overnight and pools under the unit. Exhaust hose is attached and a clear plastic small hose also, which runs from the rear of the unit inside the exhaust hose. Is there a "well" or water tray inside which we cannot find? Model is MF8000E.Azny helpful advice would be most apprciated, thanks!
  • tenoredivo Jul 08, 2010
    Even better than a quick fix. Thanks so much for the manual! Now I can (hopefully) fix further issues that may arise.
  • 2,926 Answers
The link below should help you with all the info you need for this unit. You can print it out and always have a copy.
http://www.amcorgroup.nl/upload/files/MF%208000E%2010000E%20multilingual%2026-01-2007.pdf
Posted on Jul 08, 2010
  • GetMeOttaHere Jul 08, 2010
    Your welcome and thank you for using Fixya.
Water is leaking from my Breville Barista Express Espresso machine's water tank valve.
u r is the 4th problem with the same unit. take it bak to the store and git another 1.
Feb 23, 2015 | Breville The Barista Express BES860XL Open...
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
Leaking from inside unit
What is leaking? If it is water, you need to find the drain pipe leading from the inside unit to the outside of the house, and open up the obstruction in it. You could push a wire up through it, or send some compressed air up it. The drain pipe is probably near the ground next to the foundation or in the ceiling of an outside porch.
If this is a window unit leaking water you need to clean the obstruction out of the drain pipe or hole on the outside of the window, probably at the bottom outside rear of the unit.
I wasn't sure from your question if it is leaking water, or leaking refrigerant gas. If it's the gas you probably need to call an A/C repair service.
good luck,
genetuck
Jan 15, 2011 | Carrier Heating & Cooling
Air conditioner unit is leaking water from the bottom
Hello my name is Heath it will be my pleasure to assist you. First use a level and make sure the unit is level front and back and sisde to side. Next be sure the drain hose is not plugged or stopped by any debris.
Jun 03, 2010 | DeLonghi A120E Air Conditioner
Air Handler leaking
First make sure unit is level. Drain pan may be dirty. On the rheem or Ruud unit the back of the pan gets stopped up. Ithas small holes that let the water by and they get stopped up. Now even though your drain is clean you may have a stopped up dain pan. Check this > These are problems you can take care of your self. Open up the top panel of your unit and you can look down on the drain pan. Check for dirt and stoppage near the outlet of the drain pan. You amy also have a cracked drain pan but I doubt it. Rus
Jul 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Leaking in the maytag m6p09s2a*b
Do you have the Manual to read the trouble shooting page?
How old is the unit?
If not here is a web site to acquire the manual
http://homeappliance.manualsonline.com/ex/thread/view/idThread/326907
Bless you ngafm Waiting for you answer!
Aug 21, 2008 | Maytag Portable Air Conditioner M6P09S2A
2 year old kenmore elite water leaking in freezer area
Does this happen when unit is in a defrost?? If so, sounds like the drain line is clogged.The hose and pan are located under the unit.You can access this by removing the cardboard back cover.Find the drain line tube.I'm sure the drain opening at the evaporater is iced over.You will have to unplug the unit and keep the doors open to defrost.(Removing product in unit will decrease defrost time.) Maybe an hour to an hour and a half.Could be longer!! Try using a wet/dry vac to clear.
Nov 25, 2007 | Kenmore 53642 / 53644 Side by Side...
Amcor MF8000E Air Conditioner Logo
69 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
