Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My TI 84 calculator freezes
My TI 84 calculator is not working. It turns on then freezes. I pull the batteries out and replace them and it says "RAM Cleared" and then freezes again. Need help
  • kakima Jul 08, 2010
    Remove all four AAA batteries. Press and hold the ON key for at least ten seconds. Replace the batteries. Turn the calculator on. Does it come on and work normally now?
9+3<5-6(1+4)>
Posted on Jul 11, 2010
My ti-84 silver edition calculator is not working at all. I have changed the batteries and the back up battery and still nothing but the black checkerboard square is on, it wont even let me turn off the...
If your calculator display the checkered cursor it means that the memory is full and you cannot type in anything. Clear the memory by resetting the calculator.
Press [2nd][Mem] then select [7:Reset]
Under the first Menu RAM select 1:RAM then 2: reset
Nov 06, 2012 | Texas Instruments TI-84 Plus Calculator
My TI-84 is freezing on a screen that says RAM cleared. Ive tryed putting in new batteries and back up batteries
I had this problem with my TI-89. Try taking out all batteries (including backup) for a good half hour to an hour. It fixed my calculator.
Jun 06, 2011 | Texas Instruments TI-84 Plus Calculator
Everytime I turn on my calculator I get a messsage that says "TI-84 Plus Silver Edition 2.43 RAM cleared" and my calculator freezes and won't do anything. Please help!
Welcome to Fixya. To be able to fix the issue please click on the link below. It provides the steps on how to clear the error message.
TI-84 Plus Silver Edition 2.43 RAM cleared Fix
If you hve questions please let me know. Thanks for using Fixya.
Apr 08, 2011 | Texas Instruments TI-84 Plus Silver...
If Texas Instruments TI-84 Plus Calculator hangs on screen "RAM CLEARED" , what should I do?
You should try a few different things:
1) Press the Clear button
2) Press the On Button
3) Remove and replace the batteries
If the final step does not work, you should also remove the backup battery. This is located UNDER the AA batteries. You will need a small screwdriver to remove the cover. Replace everything and turn the calculator back on.
Feb 12, 2011 | Texas Instruments TI-84 Plus Calculator
TI-84 Calculator does not turn on.
The applications that run on the TI84Plus Sliver Edition run without a hitch on the TI84Plus and also on the TI83Plus. The only major difference between the 84Plus and the 84Plus SE is the amount of flash memory.
Here is what I would suggest to you.
  1. Replace the main batteries with fresh ones.
  2. Adjust the screen contrast: a. Press [2nd] key and release it. b. Press and HOLD [UpArrow] to darken or [DownArrow] to lighten screen.
  3. Clear the calculator Ram. Usually it is cleared if the calculator is left without main batteries for a while,but you never know.
  4. To clear the Ram, press [2nd][MEM][7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the "Ram Cleared" message.
  5. Go to the education.ti.com, and download the TI Connect software, if you do not have it already.
  6. Install it on the computer and run the program.
  7. Then connect the calculator to the computer using the TISilver Link USB cable or the Standard USB to mini B cable (if you have one).
  8. Turn you calculator ON
  9. In the TI connect program window, press the Updates button.
  10. The TI connect should recognize you calculator and ask you what to download.
  11. At first select to download the latest OS (version 2.43 at this time).
  12. Later you can click the Updates button and select the Latest version of the applications installed on calculator.
If you calculator does not suffer from hardware problems, your calculator should be restored to health.
Hope it helps.
Dec 14, 2009 | Texas Instruments TI-84 Plus Calculator
RAM CLEARED?
The most likely reason is that the backup battery is drained. Change the backup battery. When you get the Ram Cleared message, just press [CLEAR] to erase the message and start using the calculator.
Hope it helps.
Oct 28, 2009 | Texas Instruments TI-84 Plus Calculator
Frozen calculator
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=90524&nUsePub=NO&JServSessionIdrootdlek22=z6c2ohx3v1.n6LzoN8M/AzOnMTOogTxpQOUtxCLbx0Ka0--&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGC5A4DDBCF3F0595853A68C079E5256B1556E2E93FB96ACB00A6AFBBC9B77BE7654B72492D9041952FB73A07FF7EFF0FB73
Here's a link to the troubleshooting thread from Texas Instruments about this particular problem, hope this helps!
Jul 10, 2009 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Feb 23, 2009 | Texas Instruments TI-84 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
2,337 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
