Question about Sony MV-900SDS Car DVD Player
I have a sony mv-900sds it was working fine but the screen came loose so I removed it from the car and now the DVD does not want to work.
  • en4lucy Jul 07, 2010
    is there an anti-theft feature on the Sony mv-900sds
  • Sony Master
  • 6,993 Answers
is it that the DVD is not powering on, or its refusing to play discs?
Remove the player again, cross check to make sure everything is intact, and try again. Its should be something minor since its was working perfectly before you removed it.
Take care.
Posted on Jul 07, 2010
    it refuses to power on, do you know it this devise has a anti-theft feature that is not letting me hook it back up.
  • Walesarumi
    Walesarumi Jul 07, 2010
    if it refuses to power, then is should be a power related problem. Check if there is power entering into the player from the battery. Also check if there is no wire disconnection.
    I don't think its an anti-theft issue. Power is not entering into the player, that's why its not powering on.
    You can check you fuse box, if now fuse is blow. Also, trace the wire from the battery to theplayer.
    Good luck.
  • 712 Answers
Since the screen was loose, the wiring to the screen might have been detached due to the shakes from the car. Give it a check.
  • 1 more comment
    there were no wires loose i make sure of that, it seems that there is no power going into the dvd. i check the current and the grownds everything is fine.
    is there a anti-theft feature on this devise
  • Sebin Punnacheril
    Sebin Punnacheril Jul 08, 2010
    Please make sure that the POWER SELECT switch is set to the correct position.
    That is A: If the car has an accessory position on the ignition key.
    and B: If the car has no accessory position on the ignition key.
    NOTE THAT: A is the factory present position.
    When the POWER SELECT switch is set to B: Press POWER ON THE PLAYER to turn on. The player WILL NOT turn on by pressing POWER on the CARD REMOTE COMMANDER.
    Be sure to turn off the player after driving your car or it may cause Battery Drain.
Tip
I just did mine and I added a toggle switch to it to get it to work since it...
just run the parkingbrake wire into one side of a toggle switch, and grond the other side of the toggle switch, When the WARNING pops up on the screen, just flip the toggle on then off then hit OK on the screen, Youll be good to go
on Dec 18, 2008 | Pioneer AVH-P5700DVD Car DVD Player
No power to the dvd player.
And you check the dvd fuse or the remote wire who comes from the stereo
Jul 18, 2010 | Sony MV-900SDS Car DVD Player
I need a manual for my sony mv-900sds to get it installed
you can get it at Encompass Parts Disturbition #1-800-638-3328
Feb 15, 2010 | Sony MV-900SDS Overhead DVD/ 9" LCD Car...
DVD Stuck in player
Found out what my problem was - 2 DVDs were in the unit - need to take unit out of car (very easy - 5 mounting screws, 2 plug in power connections), remove some brackets from within the unit to get to the DVD itself and then just pull the DVD out - took me less than 1 hour - and I am not tech savvy or mechanically inclined by any means
May 13, 2007 | Sony MV-900SDS Car DVD Player
Hanging screen is loose and broken from base of DVD player
"Possible" part @ tigerparts.com or search X-2024-673-1. I think I am going to try it, because I don't want to replace the whole unit.
Jun 06, 2007 | Sony MV-900SDS Car DVD Player
Sony mv-900sds overhead dvd
probably you will need to disamble it and remove check button. But the way I need instructions to connect it, I dont have wiring harness to connect it , can you help me with this?
regards
carlos.
May 01, 2007 | Sony MV-900SDS Overhead DVD/ 9" LCD Car...
Sony MV-900SDS Car DVD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
