Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Lights are all out
The lights in the frig, freezer, plus the indicator lights inside are all out. I've tried to turn it off and turn it back on, but that didn't work. It certainly can't be that all the lights went out at the same time.
  • 45 Answers
Did all the lights quit at the same time? You can check the bulbs in a seperate fixture. in addition to the bulbs there switches operated by the door and a computer board in the circuit. I doubt either all the bulbs or all the door switches would go bad at the same time, but if the circuit in computer board went bad it might prevent them all from working.
Posted on Jul 07, 2010
Maytag Refrigerator/freezer alarm will not turn off.
check that tha fan beside the compressor in lower back is running and that condenser tubing is lint free, also check for icing on frezer back panel if so you could have a defrost problem, if all is good you may have a freon leak inside the frig walls as tubing is all metal and will rust when sitting for a long time in storage due to moisture build up from been warm outside and cool inside during normal usage in which case you may need to change the appliance at that point you will need a service call to find if there's still freon inside your frig and of coarse your control may not read the properly..
Jan 25, 2015 | Maytag Refrigerators
Signals and break lights wont work, fuse keeps blowing
You have one of them funny american things where it all works backwards so this old gnarled europeon mechanic would have a direct answer like a real proper car,although i do think this is a opel frontier in my language.What i would do here is to disconnect the fancy brake light switch that these motors have and try checking the wires at the back of the vehicle ,like inside the rubber boot from boot door to the bodywork as this is 99% of the problems i get with hatchback type doors or whatever you want to call them in whatever language you call them.Our europeon vehicles have seperate lights for all three functions ,indicators stop and side lights.plus of course the obligatory reverse and fog lights
Dec 19, 2012 | 1992 Geo Tracker
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Water collects inside the frig
usually an indication that the drain tube is clogged with frozen water or blocked woth something clean the drain tube.
Mar 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
131 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
