Question about Jack Lalanne Power Juicer 250 Watts
I want to clean my juicer, how do it take off the top part to throughly cleanse it?
  • wboudreaux4 Jul 08, 2010
    you are certainly the best at what u do, thx
  • 6,993 Answers
follow the procedure below in order to successfully take your juicer apart:
  1. Unplug the juicer power cord from the wall outlet.
  2. Pull the food pusher out of the top of the juicer. The pusher is inside the area you would place the produce in when juicing.
  3. Hold the top of the juicer with one hand and pull the metal locking bar toward you until the locking bar is off the top of the juicer.
  4. Lift the top assembly off the juicer body. Insert the crescent tool inside the two peg holes in the juicer blade. The crescent tool has two pegs on each end that fit into the holes. Hold the side of the blade with your thumb and forefinger and turn the crescent tool counterclockwise to loosen the blade.
  5. Unscrew the blade by hand and remove the blade from the juicer. Lift the filter basket out of the juicer.
  6. Lift the juice receptacle straight off the juicer body. The juice receptacle is the piece that has the juice spout.
By now, you should have successfully take the juicer apart.
Good luck.
Posted on Jul 07, 2010
INSTRUCTION TO CLEAN AFTER USE
Cleaning the juicer immediately after use makes it really easy to clean. Run few cups of water through the machine while running and make sure to use a bristle brush to scrub the screen with after use.
Aug 10, 2013 | Jack Lalanne Power Juicer (Stainless...
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
How do you take the top off to clean the bottom container after use?
The manual for your Jack LaLanne Power Juicer can be found here:
http://www.powerjuicer.com/power-juicer-manuals.php
The manual contains illustrated assembly and disassembly instuctions
You may also find the How To videos to be helpful:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
Aug 01, 2011 | Jack Lalanne Power Juicer 250 Watts
I need to clean my Jack Lalanne power juicer.
is a manufacturer secret- I think you need to keep the juicer dirty
Mar 17, 2010 | Jack Lalanne Power Juicer 250 Watts
I don't know how to clean my jack lalanne's power juicer
remove to arm that holds top slide it twards you then use tool to remove blade then remove juicing screen then the bowl (the one that says jacklallanes power juicer
Mar 02, 2010 | Jack Lalanne Power Juicer 250 Watts
How to clean my jack lalanne power juicer
Take the top part of the juicer off so that just the shreder is visable. On top of the shreder are 2 small holes on either side of the blades. a handle devise with 2 pins came with the juicer. put the tool pins into the holes and twist counter clock wise. The blade will come off then rest is simple and the unit can be disassembled. If you have lost the tool disassembly will be more dificult but can still be accomplished using a cloth on top of the blades and twiting counter clock wise. Careful though or you will cut yourself
Jan 05, 2009 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
379 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
dflynn2204
Level 1 Expert
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
