Question about Samsung RS2556 Side by Side Refrigerator
I have a Samsung Model RS2555Sll refrig. The lights on the electronic panel (outside of freezer door) went out. i.e the temp readout for the frig and freezer do not light up (only one line of one number is lite up green) Inside lights, Ice and water dispenser work...I've had doors opened...and the frig has yet to kick on. Big problem?
  • cldowdy Jul 08, 2010
    Hi...
    I'm not sure where to look for loose wiring?
    Inside/uoutside the frig?
    Not really...but thanks anyway. I checked the obvious wiring and there was nothing wrong that I could see. I have a repairman comming out tomm.
  • 2,272 Answers
The wirings are located at the top in the back side of the freezer compartment internally.And if the lights are not working then you will require the light switch and the light controlling module. To get required part click on the link directly http://www.partselect.com/MultiModels.aspx?ModelNum=RS2555&searchTerm=&RefineSearch=0 ------------ But to disassemble the unit and locate the faulty part and for total troubleshooting you will require the service manual for RS2555s model. without service manual you cannot do any thing.If you want service manual just click this link and follow the instructions in detail to repair your unit. http://jagermon.com/fileTransfer/samsung%20rs2555sl%20service%20manual.pdf
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 08, 2010
  • 484 Answers
Its not a big problem, the fault is from the wiring of the fridge, run a general check on the wiring of the fridge and you will detect the faulty connection, correct it and it will be in good condition again.
Take care
Posted on Jul 07, 2010
    Phew...
    Will the effected wiring be exposed? (inside the freezer?) Again, the lights work, so there is main power.
    Did you recieve my last question?
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
On our Samsung RS267 and 25.5 cu ft refrigerator, we have an "OF" light on both temperature readouts (freezer and refrig.). What does this mean and how can the problem be rectify so that we will...
If "0F 0F" appears on the display, the refrigerator is in DEMO MODE. To exit Demo Mode for controls on the outside of door, Press and Hold the Energy Saver and Adjust Freezer buttons at the same time for 3 seconds. To exit Demo Mode for controls inside the Fresh Food Compartment, Press and Hold the Ice Off and Freezer buttons at the same time for 3 seconds. You will hear a beep and "0F 0F" will no longer be displayed. Adjust Refrigerator and Freezer temperature to the desired settings. Allow 24 hours for temperatures to stabilize.
here is a video explaining (for all models) what is to do ..
http://www.samsung.com/us/support/owners/topic/RSG257AARS/XAA
Aug 15, 2011 | Refrigerators
The tempature on my refrig. panel continues to blink on the frig.side. I have it at the lowest settinng which is 34F. The Freezer has not moved nor is it blinking. The freezer is still holding its temp. ...
The computer has detected an error in the system and needs to be addressed by a Samsung qualified technician. They have a list of error codes that they can figure out what's wrong with the unit.
Jul 18, 2011 | Samsung RS2630SH Side by Side Refrigerator
The temperature reading on the outside door panel flucuates
Could be a fan problem, open the door and hold the door switch in, the fan should start and you should be able to feel air coming out the vents (air flow is not very strong as it comes out many vents so you will feel a cold breeze rather than a strong air flow if it is normal. Also check if you can see any ice nuild up in the back of the freezer as it may be a defrost problem and the air can't flow due to the ice build up, if this the case it will need to be looked at.
Apr 18, 2010 | Samsung RS2578BB Side by Side Refrigerator
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
The Frig Side temp. is 51 and freezer side temp. is 10 could this be the louver between freezer and frig. If so how do I get to it to fix it on samsung model rs2630sh.
I need you to check a couple things for me before we go to far. Is frost building up in freezer back panel? Are all fans inside and outside of the refrigerator. That refrigerator has a control board and we may need to have a look at it. The control board is AP4139120
But I need to hear from you first before going further. Thanks, Sea Breeze
Jun 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2556 Side by Side Refrigerator Logo
64 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
