Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The timer doesn't respond to the buttons. - Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
It is possible the child lock has been set. See if the button with "lock" symbol is lit up. Press the button to clear the light. Then try and press the buttons.
Posted on Jul 14, 2010
Control panel does not respond on Crosley Dryer Model CDE4205AYJ
Don't you just love electronic controls. On the inside of the dryer is like it always was back in the day with mechanical timers. The same old problem the old ones had is the blower wheel slips and causes overheating or a ball of lint at the base of the filter chute. This eventually blows the FUSE. Their is 2 of them fuses so look close one is usually behind a shield out of sight and may have been overlooked. DIAGRAM
Apr 29, 2013 | Crosley Dryers
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
Speed/Acceleration Button Doesn't Respond
are 2 solution, try to replace the acceleration button, or membrane for to fix it. 2) replace the complete Console.
You can call to the service support and ask for the membrane for to replace, or see if your operator manual for the part number.
Blessing
cuadra2016@yandex.com
whatsApp:+50588611441
Nov 01, 2017 | Precor 933 Premium Series Treadmill
Pushed reset button and will not respond. Red on light stays on
11/6/12
Copy following link for Utilitec LW60418 timer.
Same as Westek TMDW10, and Stanley 30418
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is reset with one-button.
Unlike some timers that require 2 button push.
Push in reset button firmly with paper clip, and hold for several seconds. Repeat.
This action will clear timer memory.
If reset does not restore functionality, then timer could be bad.
This timer has 1 year limited warranty.
Suggest buying new timer at Lowes, and returning defect timer in new package.
Nov 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
The timer lights blink together slowly and rhythmically, but the timer doesn't respond to the program button being pressed.
I can't be sure but on the model 604F, this indicates the battery needs to be replaced (on 604F it's a 9V battery).
Jun 22, 2011 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
How do I change the clock on my sony bravia tv?
Press the HOME button on the remote. You want to find the CLOCK/TIMERS section. Navigate to SETTINGS. Use the arrow keys to select item. Use the arrow keys to set current time. Press RETURN to display the confirmation. Select YES to save the changes.
Sep 04, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
102 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
