Question about Garmin nuvi 255W GPS Receiver
No touchscreen response on my new Garmin car gps
When I try to program my gps, nothing happens. The device does show the correct current location but I can't set up any destinations.
  • Garmin Master
  • 6,993 Answers
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
  1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
  2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
  3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
  4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
  1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
  2. Hold the switch in the position for at least eight seconds.
  3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
  1. Turn your Nuvi off by sliding the power switch to the left.
  2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
  3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck
Posted on Jul 07, 2010
Garmin nuvi 205w gps black dot problem
Please be more specific. There is a calibration screen where black dots are shown and you press them to calibrate the touchscreen. Is this what you mean? If you press them and nothing happens, your touchscreen may have failed and needs to be replaced.
May 27, 2013 | Garmin nuvi 255W GPS Receiver
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Mar 29, 2013 | Garmin nuvi GPS
Nothing happens when touching screen. Thought I needed a new battery, after purchasing and installing....still nothing HELP!!
Battery has nothing to do with the touchscreen, unless you disconnected it to the main board while changing the battery. This is a common problem with this series. Usually caused by a failed touchscreen. Please see this link for more info. Too much info to retype here.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 10, 2011 | Garmin Nuvi 660 GPS Receiver
Touchscreen doesn't work. It happened suddenly. Garmin nuvi 255
try recalibrating the sceen. to access, turn unit on but hold power switch to the left until touchscreen config shows (35-60 seconds) follow prompts onscreen
Mar 19, 2010 | Garmin nuvi 255W GPS Receiver
This morning my gps froze and would not allow me to program an address or do anything. I un-plugged it and I just could not get it to work properly. What can I do to correct this? Or, do it need to be...
Please see this link:
When the touchscreen will not accept any commands (non-responsive) then it has failed and needs to be replaced.
- Jim
Dec 03, 2009 | Garmin Nuvi 350 Car GPS Receiver
My garmin nuvi 350 is locked onto: "Do you really want to erase all user data?" I've tried resetting...what to do...I press NO and it highlights YES and nothing happens..just locked.
Your touchscreen is jammed or defective and is telling the GPS that there is pressure on the touchscreen constantly in that area. It needs to be replaced. Please see this link:
- Jim
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
Map update notice screen
HOLD THE ON OFF SWITCH DOWN AND youPRESS RESET This should reset it back for t
Jun 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Touchscreen not responding
Try to find how to calibrate the touch screen in the users manual.
May 29, 2009 | Garmin nuvi 250W GPS Receiver
Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Sep 25, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
29 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
