Question about Vacuums
How do I change the fan on my model 2HD kirby
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Generic problem for all Vacuums
How do I change the
posted by Rogor on Apr 18, 2008
How do I change the fan on my model 2HD Kirby
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st you need to remove the head with the revolving brushing by dialing off the belt and undo the Kirby lock @ the top o the bell housing. Remove the head and that will expose the fan and the fan housing. The fan housing is held on by a couple of screws and once you removed the screws then you need to separate the fan housing from the motor section, it is held on by a Kirby fan housing sealer that is clear – so try to separate the fan housing with a knife or screwdriver, once the fan housing is off the Kirby fan is screwed on I believe either clockwise or counter clockwise and un-screw the fan and follow the reverse situation on installing the fan but you need to use the clear Kirby Fan Housing Sealer to re-seal the fan housing and let it dry and wipe of the excess clear sealer before putting it back together again. Always remember on the Kirby vacuums – use genuine Kirby parts on the repairs, it does make a difference. Then go back and place the Kirby head back on the vacuum – lock it on place and then re-dial the belt onto the Kirby fan shaft, plug your vacuum in the wall outlet and test run the vacuum.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874
Posted on Apr 18, 2008
A Kirby Heritage II model 2HD Use and Care Manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/heritage2/18F36C000B8A1B4BC17B195AFA60B506/Heritage%202%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 31, 2010 | Vacuums
I need to replace the fan and am not sure Kirby G 4 A
Greetings from GoVacuum,
We've shot a video showing you detailed instructions on how to replace the fan on a Kirby Generation vacuum cleaner. The video is in two parts below. If this video was helpful to you, please be sure to rate this Solution by clicking the four Thumbs Up icons in the top right hand corner of this Solution;
Changing the Fan On a Kirby Generation Video, Part 1:
Kirby Fan Change Video Part 2;
Thanks,
Chris Jones
GoVacuum.com
Mar 03, 2010 | Kirby G4 Bagged Upright Vacuum
My Kirby 2HD has started making an odd roaring noise but still works fine. I have taken the front assembly off and cleaned and adjusted the roller and checked the belt. The noise seems to come from the...
It is quite possible, it just needs lubed. The motor comes in direct contact with dirt so, you have to make sure the front bearing has a drop of oil on it from time to time. If it starts to scream at you within one month, after oiling, the bearing needs to be replaced.
Oct 05, 2009 | Kirby Heritage II Vacuum
Looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
Jul 23, 2009 | Kirby G6 Bagged Upright Vacuum
Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
Jul 10, 2009 | Kirby Vacuums
Kirby legend 11
Just got done fixing our Heritage II model 2HD, it had a dirty safety switch. Both the hose attachment and the roller housing depress a plunger to close the switch, thus sending AC to the motor brushes. You might want to try pushing this in and out repeatedly with your thumb, power removed of course, in an attempt to make better contact. If this works to restore power to the motor, it'll be just a short time before the problem repeats itself. You'll have to remove the switch to give it a thorough cleaning. I didn't have any contact cleaner handy, so I wound up using WD40. Hope this helps. Kevin H.
Apr 04, 2009 | Kirby Heritage II Vacuum
Replacing the bearing behind fan on a kirby heiritage II 2hd
I don't know what model of Kirby you have but on all Kirby's that I know of you have to remove the fan.
Here are two vid's on fan removal for a generation series vacuum.
Feb 26, 2009 | Vacuums
Fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby 2hd how do i put the belt on this vacuum thanks
On the Front of sweeper is a Tab Turn it and it will release the Beater Bar assembely Put the Belt around the Bar and put the Belt on the inner tab Turn and the Belt should go around motor Good luck ttech
Jul 24, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
145 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
