Can someone tell me what this code represents for a Designjet 5000 wideformat uv printer and how to solve it :0f0100 037c02c2
  • 493 Answers
Hİ,
System error 0F0100 037C02C2 occures when using a 3rd party RIP (Raster Image Processor) application. This bug is fixed in system software (firmware) version A.02.12.
You may try to upgrade your system software (firmware) to the latest version.
Hope this helps.
Posted on Jul 07, 2010
HOW TO SOLVE ERROR CODE 79.2:04 IN MY HP DESIGNJET PLOTTER?
To answer your question in regards to a list of error codes on a diagnostic test, I have never seen a list and I have been looking for a really long time. From my understanding, the diagnostic report means more to the engineers. Usually each digit represents some aspect of the test. Are you having problems with the printer or are you just trying to understand the test page that printed off?
May 11, 2016 | HP Office Equipment & Supplies
0B0007
The error code means the vacuum fan is not detected.
Replace the vacuum fan. If that does not fix the problem, replace the Main Logic board. The fan can be ordered from: Designjet 5000 5500 Vacuum Fan and the PCA from: HP Designjet 5000 5500 parts
Jun 26, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error code 0b0006
Hello. This error code indicates that the 5VDC and ground are shorted together by the trailing cable. Replace the trailing cable.
May 21, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error codes
Error code 0C0040 is caused by the drop detector not detecting drops from at least 2 print heads in the same area. Run print head recovery on all the print heads and see if that clears up the problem. If not, then clean or replace the drop detector. Drop detector can be ordered from: http://www.lpscomputer.com/p-2512-c6072-60179-designjet-5000-5500-drop-detector.aspx
Sep 30, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
I have a Designjet 5500ps Printer and it is leaking blue ink, when printing, all my research indicates that I need to replace the carriage tube connector, but I am unable to find the replacement part.
Hi there
May be you can try to contact any Authorised HP Service centre for your probelm. Could you give me your correct location so i can tell you whome to contact?
Alternatively you can try to see where the leakage is taking place and try to seal it with silicon sealent so it can atleast last untill someone attends to the probelm from HP.
The technical term for it is INK TUBE ASSY. But make sure and tell the HP people about the size of the plotter that is 42" or 60" and also keep the Product Number and Sl. No. of the machine handy which is required by HP technical team. (You can find it at the back of the plotter)
Click here to find all the spares for your plotter.
Aug 24, 2011 | HP DesignJet 5500PS InkJet Printer
After converting our 60" HP
Have you tried to revert back to the dye inks?
If that solves the problem, then your UV ink tubes have a bad control board.
(you did change the ink tubes system, printheads and ink ?)
If the error code continues, replace the Main PCA.
Jul 19, 2011 | HP DesignJet 5500PS InkJet Printer
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
The HP DesignJet T1100ps printer has a 79:04 error code. What kind of error is this and how can I solve this problem? please, help ! !
hp will never tell you but this error is a kind of a catch all error basically the service manual says to reload the firmware. check the file you are sending. i have seen a bad file cause this error. hope this helps.
Jun 09, 2009 | HP Designjet T1100ps Printer
Replace HP designjet carriage 5000 belt
you need some skill and expertise, if you have, download the service manual
http://www.eserviceinfo.com/equipment_mfg/HP_22.html
Feb 18, 2009 | HP Designjet 5000 Printer
"System Error" has occurred when the power is on.
same problem....what is the fix? - asap PLZ. In advance, thx
Dec 15, 2008 | HP DesignJet 5000 Printer
k24674
