Question about Goldstar R5208 Air Conditioner
Needs a recharge
Can I recharge this?
    President:
  • 1,796 Answers
Hi!!
Window type A/C units do not have service ports. Your best bet is to get a couple of universal piercing service valves to check and recharge R-22 gas if needed.
Don't forget to rate this post. Good Luck!!
Posted on Jul 07, 2010
2000 cadillac deville recharge ac how to
Melvin, Recharging a cars A/C system. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Right Wrong way to recharge AC
2003 Escalade charging AC
How To Recharge an AC System EricTheCarGuy
How to Properly Recharge Your AC System
Jun 19, 2016 | 2000 Cadillac DeVille
A/c recharge car
If you need a recharge, you have a leak. You will be losing refrigerant 24 hours a day / 7 days a week and need to recharge when it gets low. Most garages and shops offer recharging A/C units from $99 and up. You might want to get an estimate to have the leak fixed before recharging as that would be a "once & done" arrangement. If the leak is in a location that is hard to access, it may cost over $1000 to fix - in which case recharging once or twice a year may not be quite so bad.. Good luck!
Jul 22, 2015 | 2007 Honda Odyssey
How do I have the compressor recharged?
the unit does not require 'recharging' unless you've had a refrigerant leak - in which case you will need a qualified AC TECH to recharge it for you, after, he/she has found and repaired the leak.
But, as I said above, without a leak in the system you do not need to recharge it.
Aug 04, 2011 | Maytag M7DH45B2A Dehumidifier
How to replace battery of wireless laser mouse mi
On the Top on the Mouse u can see the Battery u need to Remove the old Battery's and Replace with New battery see that you use Rechargeable battery because ordinary battery life spam is very less and u need to change the batterys for every 1 month so if u use the rechargeable battery then u need not change battery for 1 month at least for 5 or 6 months the rechargeable battery work and u can keep and spare rechargeable battery when every needed and try to purchase a Sony Rechargeable batterys deepakkumaar.jpg
Dec 14, 2010 | MSI Computers & Internet
Power On Board 3 Million Rechargeable Spotlight
Vector is now owned by Black and Decker since 2006, you can order one at their website, you will need to enter the model #, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jun 13, 2010 | Vector 3 Million Candlepower Rechargeable...
The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Feb 03, 2010 | Braun Health & Beauty
Identicial problem, and yes in the same room for 3 years
It's a sealed system wich normally doesn't need to be recharged. (compare with a fridge)
Frans Verhees
service engineer.
Sep 17, 2009 | DeLonghi Pinguino PACL90 Portable Air...
What symbol is used when the battery needs to be recharged? Is it ok to recharge the battery before the symbol appears?
battery's life is governed on the number of recharges. so it is always recommended to recharge a battery only when it has been discharged completely. generally a blinking battery symbol denotes that the battery needs recharging.
Aug 07, 2009 | Olympus Stylus 710 Digital Camera
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
Recharge slot is broken. When I try to recharge my phone, there is no sign of recharging. I tried with two different rechargers but it is not working. Any ideas?
u can change recharging socket but it need skill & soldering gun etc ,some cdma mobile have alternateive socket such as lg 2330 6130 2230 etc
Jun 09, 2008 | Cell Phones
Goldstar R5208 Air Conditioner Logo
201 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
