Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
TV picture does not turn on
It seems to be trying to spin up, I hear the repeated spinning, whining sound, but ultimatly get no picture. It is 90+ degrees in an unair-conditioned house, so it could be too warm for the machine to fucntion.
  • RCA Master
  • 8,457 Answers
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv tech.to replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
Posted on Jul 07, 2010
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
I have an RCA Scenium DLP 50 TV. The TV started making a loud noise (like a computer fan) going out. The noise would go away when we powered off the unit and the bulb shut off. Eventually there was no...
yes ... you could have a color wheel problem.. this set get color from a spinning wheel called a color wheel.. when you unplug this and plug this back in you should hear a whining motor sound. During the "bootup" sequence this motor spins this wheel to test to see if it reaches speed. This is a motor that moves and anything that moves eventally dos not. i see this problem often in the shop and if it is the problem there not all that difficult repair. the hardest part is finding the color wheel
Oct 18, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
My TV will not turn on. When I push the power button, I hear a click and what sounds like a hard drive spinning up and then slowing down. After spinning for about a minute, it turns off. In about a minute,...
No,Ur tv have a colors wheel,it dead.The spinning u hearing is the spinning of the colors wheel is rubbing against it base axis.Hire a tv tech for this job,replacing the colors wheel is hard,because require take out many machanical parts,before,u can even replacing the colors wheel itself.
Oct 03, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
michtech
Feb 11, 2009 | Samsung HL-R6167W 61" HDTV
Negative image and then black and won't turn off!
The negative image on the screen is the DMD board (Digital Mirror Board). The cycle sound is the color wheel trying to spin but if the DMD board is going bad, it will effect the color wheel and not spin. There for your image will freeze.
Mar 26, 2008 | Samsung HLN5065W 50" Rear Projection...
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Dec 19, 2007 | Washing Machines
Epson 925 printer spinning/whining action
This is the typical symptom of a paper missed & jam. Clear the paper larger and try again. BE SURE TO UNPLUG ELECTRIC PLUG.
May 02, 2017 | Epson Stylus Photo 925 InkJet Printer
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
197 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
