Question about Sharp CVP10NC Air Conditioner
Remote Control is missing.
How can I get a new remote control for my CVP1ONC Air Conditioner ?
4 Suggested Answers
  • 13433 Answers
SOURCE: The error code E1 is
E1 means you need to clean the filter.
Posted on Jul 28, 2008
marked
  • 6487 Answers
E1 is refering to the air filter. If turning the unit off and unplugging doesn't reset it then you probably have a PC board or sensor failure. None of these units can actually detect a dirty air filter. All it does is set a timer that turns the E1 on after what the manufacture determines is average.
Hope that helps.........
SOURCE: Sharp A/C remote CRMC - A310JBEO RO3 (AAA) 2PCS is not working
There are two AAA batteries hidden below the keypad under the sliding cover.
Gently prise off cover to real batteries, and replace them.
Posted on Jul 03, 2009
I need to purchase the remote control for Danby premiere dpac13009 Where I can find it ?
Ebay, only 1 available. $55 free shipping.
NEW Danby Premiere Room Air Conditioner Remote Control Transmitter A2529...
Appliance Parts Pros. $48 + shipping. I would call first because they don't have it in stock. Claim of 5-6 days may not be correct.
http://www.appliancepartspros.com/danby-dpac-remote-control-a2529-950-ap4556076.html
Repair Clinic $49 + shipping. Again call first because they don't have it in stock.
Remote Control A2529 950
Jul 27, 2016 | Danby Premiere 13,000 BTU Portable Air...
Can the unit operate without the remote control
Yes, by pressing the power button on the unit. It is factory set to cool to 68 degrees and maintain that temperature. To access any other settings you must use the remote control. The part # for the remote is CRMC-A750JBEZ
Aug 14, 2013 | Sharp CV10NH Air Conditioner
I have a GE Air Conditioner ASW 180AS1. It has a WJ26X10084 ARC-715 remote control that does not work!
You can access the circuit board by first removing one small phillipshead screw from inside the battery compartment. Next, pry the case apart at the parting line toward the front of the remote. On either side of the IR LED's you'll be able to push a very small flat tip in there and get the case to start coming off.
Once you have the case off, you cannot miss the capacitor. Its either blue or black with words like 4.7uF (microfarad) 50V 85degrees with a stripe on the right side.
Use a 30 watt soldering tool ($7 at an electornics store) to heat the solder mount and a pair of pliers to tug gently at the wire as you remove them from the liquid solder. Install the new capacitor into that same solder paying special attention to the matching stripe marking on the capacitor and PCB. Make sure you do not overheat the new capacitor as you install it.
Jun 21, 2012 | GE Air Conditioner Remote Control -...
The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
Jun 20, 2009 | LG LSC121PMA Split System Air Conditioner
Just opened up box and no instruction booklet nor remote control included
Contacted Danby- Direct and they are sending me the missing parts from my order...
Thanks for you help.
Jun 02, 2009 | Danby DPAC120068 Air Conditioner
Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Jan 02, 2008 | Heating & Cooling
Air conditioner
Some some remote control have RST or RESET button, you have to push this every time you change the battery or for malfunction remote control. You can find this either in front of remote control or at the back of the remote in battery compartment.
Jan 01, 2008 | Heating & Cooling
Air conditioner remote
- check if the battery is still good
- check if the receiver of the unit is clean and no obstruction.
- Some of remote control have a reset switch, every time you change it with battery you have to reset it.
- Some of remote control have A and B selector at board and remote control, check this if they set at the same frequency.
- To check if the remote control still working you have to test your remote control to other unit with same model as yours. If its not working then replace your remote control. But if its working then you have to replace your receiver board.
- Some remote control have to be reconfigure so you have to read your manual.
Dec 29, 2007 | Heating & Cooling
Sharp CVP10NC Air Conditioner Logo
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
