Question about Samsung SyncMaster 203B LCD Monitor
AMW 19" RFR LCD display monitor. Takes a long time to come at start or after sleep mode.
  • action1313 Jul 11, 2010
    AMW A911B 19" TFT LCD display: after computer goes into sleep mode, the monitor does not come back on. I have now attached it to my laptop and it worked the first time, but not since. HELP PLEASE
  • action1313 Jul 12, 2010
    Thanks so much for the help. I found FIXYA.COM in an AARP Bulletin and have already told all my friends.
    President:
  • 4,070 Answers
Hi! Usually when it takes some time for display to appear is the monitor is faulty itself. It will run but take some time for the display to appear. You will just have to wait for its break point before replacing it. Try swapping the monitor if it still performs the same. If it is, then we are facing a video card problem. You may stop worrying bout the monitor, just replace the video card. Hope this helps and have a good one!
Posted on Jul 11, 2010
  • 3 more comments
    thanx... so how do I replace the video card?
    ...and if I bought a new monitor and DID NOT replace the video card, wouild I have the same problem?
  • dj_relly999
    dj_relly999 Jul 11, 2010
    Before replacing the monitor please borrow a monitor from a friend so that we will know if its a video card or a monitor problem though its most likely a monitor issue. Lets just try this for you to save some money. Once you borrowed a monitor i'll walk you thru. If its a monitor problem you dont have to replace the video card.
    thanks for the help DJ --- I have the monitor hooked into another computer, my laptop... and for the most part it is coming on after sleep mode... altho NOT every time.
  • dj_relly999
    Alright... then its a monitor problem. If you can tolerate the performance then fine, atleast we can save the money till the day it reaches its break point.
  • Samsung Master
  • 6,993 Answers
the problem might not be from the monitor, it might be from the computer. If the computer does not boot, there won't be signal on the monitor.
Sometimes, the computer VGA may be failing, and won't be signal on the monitor.
I would advice that you test the monitor on another computer and see if it will do the same.
If it does the same, then it means the monitor has develop a fault and needs to be serviced. In this case, you will have to take it to a repairman to fix the fault for you.
Take care.
Posted on Jul 07, 2010
  • 1 more comment
  • action1313 Jul 07, 2010
    thanx for the quick response. No problem with the boot-up. The monitor seems to be hit or miss (more miss lately). My other computer is a laptop. Can I try the monitor with the laptop?
  • Walesarumi
    Walesarumi Jul 07, 2010
    Yes, its possible. You can try the monitor with your laptop.
    I hooked the monitor into my laptop and it came up quicker. And it came right on after sleep mode. So it's obviously something with the computer. What to do?
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
LCD Monitor takes time to display HANNS.G Model
there is leak capacitors problem inside of your monitor they need to be replace so that your monitor work normaly
May 22, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
AMW 19" LCD Monitor
go to NVDIA web site download the latest driver.
you need at least 32bit color to setup the monitor.
the 8-bit color is a default, that is why the monitor alway return to default size which is 800x600.
19" monitor should have minimum of 1280x1024 with 32 color.
don't up the color 256bit. the color will be off on the monitor.
Jan 25, 2009 | Dell Dimension 4600 PC Desktop
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
Sep 04, 2008 | Proview PL926WBi 19" LCD Monitor
AMW F199B 19 Inch LCD Monitor - No Red
I just changed PC and and I have a "AMW F199B" monitor that will not produce sounds now. I do not have any of the original software for the monitor. What do I do?
Thanks
Jun 14, 2008 | Advueu Technology AMW-F196B
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Samsung SyncMaster 203B LCD Monitor Logo
99 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
