Question about Saws
I have a 12" Craftsman Band saw and the blade keeps coming off. What adjustments do i have to make to put on a new blade and keep it on?
  • 10,319 Answers
The wheels have to be true at 180 degrees facing each other. Use a metal rafter square if needed to align the trueness of these wheels. If one is angled out ward the blade does come off the wheel
Posted on Jul 07, 2010
2 Suggested Answers
FixYaSteve
  • 57 Answers
SOURCE: I have a 12" Sears - Craftsman - Band Saw and the
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Posted on Jun 14, 2010
Testimonial: "Very helpful. My problem is that I have moved, I'm 90 years old and I can't find my manual. But thanks. I'll keep working on it. Foster Williams"
Get a 12 "Sears craftsman band saw blade model no 113.279521c
I'm using Haltbar band saw blades that I got from sawblade.com . They have great quality band saw blades. I ordered 10 blades from them last month and shipping was free.
Oct 18, 2014 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Band saw blade keeps coming off
Set up your band saw properly. There are several reason why band saw blade keeps on coming off on the wheels: loose/wear tire, improper guide adjustment, incorrect tension, over feeding wood stock or the problem could be on the blade itself. Try to change your blade, I got my band saw blades on sawblade.com . I suggest you watch band saw tune up tutorial videos on youtube. Hope that helps.
Aug 13, 2014 | Black & Decker Saws
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
I have Sears- Craftsman 10" band saw #113.244510. after installing new tire the blade tracks to the rear. Have followed manual but cannot solve proble- any suggestions?
Check this blog first. Are you installing a new blade? If the blade is running backwards, you just have to reverse it, turn inside out. Try watching the Alex Snodgrass' Youtube video Band Saw Tune Up .
Oct 17, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Why doesnt the wheels on my band saw turn when I turn the saw on?I can't even turn them when the saw is off.
Most likely the blade has come out of position and jammed. One place to check is at the guides just above and below the table.
To be sure the guides are correct, Google on "adjust band saw" to find out how to adjust them.
Jan 19, 2011 | Craftsman 12 Tilt Head Band Saw Owner...
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I have a Craftsman 10 inch band saw. The blade keeps coming off. I can't find my manual. How do I adjust the alignment on it?
the blade tension shaft in the rear top of the saw should also have a tracking adjustment knob that tilts the top wheel. Open the top guard and spin the top wheel by hand and adjust the tracking knob until the blade atays on. Better unplug the saw until you get this done, then you can power the saw back up and fine tune the tracking while running until it is perfect. hope this helps you.
Oct 17, 2009 | Saws
Bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Aug 22, 2009 | Craftsman Saws
Band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Mar 31, 2009 | Delta 28 168 Bench Band Saw Blade 56 1/8...
Straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Saws Logo
145 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
