Question about RCA HD52W59 HDTV Projection Television
My RCA SCENIUM HD65W20 TV would not turn on. No power. I opened the back and found the 6A 125v fuse next to the power cord blown. I replaced it and connected the power cord to the tv and the fuse blew again. I once again replaced the fuse, but this time I connected the power cord to the tv first and then connected it to the wall outlet and the fuse again blew. It seems there is some short somewhere. Please advise.
  • salsabor69 Jul 08, 2010
    I need more advise before I can decide to try and do it myself or call a technician. Thank you
  • salsabor69 Jul 09, 2010
    No, but thank you.
  • 4,889 Answers
If the main fuse is blowing then it is most likely due to the surge from the outlet itself. As you may know power coming from the outlet first passes through the 6A fuse that you have mentioned. A voltage stabilizer may also help your cause.
Posted on Jul 08, 2010
  • 484 Answers
There is no short anywhere in the television.
The reason the fuse keeps blowing up is simply because the power supply is too high for it to regulate. Then the fuse will continue to blow as long as it is still being plugged to that same power source.
Get a stepdown or a stabilizer and connect the television to it, do not plug you television to a direct power source. Make sure the television is unplugged and turned off when you are fixing the fuse, then you should plug it to a stabilizer or stepdown first before turning it on after fixing it.
Also you need to ensure that the fuse you are fixing in it is also a 6A 125v fuse.
You can also try a fuse with a higher Amp and Volt.
Ensure there is no form of partial contact when you are fixing the fuse back in it.
Secure also that the power chord is intact and is not having any form of partial contact in it. After plugging the cord, check if it is hot, then you can detect if it is faulty and needs replacement.
Take care
Posted on Jul 07, 2010
    Thank you for your input. The TV has been off since November and when I disconnected the power cord today before starting to work on it, the cord was not warm or hot. Also, all I've used is a 6A 125V fuse. So you say that once I replace the fuse, to connect the TV's power cord to a stepdown transformer so that the fuse can regulate. How soon would I be able to connect the TV back to the normal power source without the fuse blowing? When you say to make sure that the fuse or power cord do not make any partial contact, contact with what? I have to use a long tweezer to try and squeeze the fuse into the uncomfortable position where it's connection is and many times it slips off onto the baseboard. It's not that easy. I have to go out and buy some more fuses since I only had two which blew out. Thanks again for your help and take care.
How do you test a fuse
How do you test a fuse?
• for RCA FL231
(400ma, 125V) +40V Supply Power Supply/Deflection PCB
OEM RCA FUSE RCA259213 FL231 400MA 125V 3960400000 ...
• for
FL221 (1.25, 125V) -13V Supply Power Supply/Deflection PCB
FL251 (1.25A, 125V) +13V Supply Power Supply/Deflection PCB
FP400 (6A, 125V) AC Input Mains Input Doubler PCB
FP602 (1A, 250V) DVD Power Supply Mains Input Doubler PCB
here are some links to guide you:
http://www.electronicrepairguide.com/how-to-test-a-fuse.html
http://www.dinosaurelectronics.com/Test_Fuse.htm
hope these helps,
thanks for choosing fixya for assistance!
Aug 25, 2012 | RCA HD52W59 HDTV Projection Television
Tv not coming on just red light flashing on and
thomson scenium jw 611s not coming on just red light flashing on and off at front of tv
Jul 13, 2010 | RCA Scenium HD65W20 65" Rear Projection...
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
RCA 42in. Projection TV will not turn on.
check the fuse on the Main filter board ( The board where the power cord attaches to) as that fuse can often be blown and that will cause the set to be completely dead.
Apr 12, 2009 | RCA Scenium D40W20 40" Rear Projection...
No Power on rt2580
According the parts list on the model unit your fuse is suppose to be F101,FUSE 6A 125V. Is it possible that you have an undersized fuse?
I don't believe that one amp differents would cause your unit to blow like that but, you never know. More than likely you have a bad component in the power supply or power amp.
Then again, with an average replacement cost of $150 online; it not worth getting too deep into the repairs.
Jan 29, 2009 | RCA RT2500 System
RCA HDTV R52WH74YX61 blown fuse
there are 3 small red rectangular shape objects to the right of the flyback transformer these are fuses the fl231 most time goes bad .fl231 is the location number under the green circuit board. the location number can also be wriitten on top(brown side of the cicuit board)
you may have to put back the .6a you took out was it ok?
TRITRONIC ELECTRONICS sell parts . cathray 416 241 1106 sells also
Nov 22, 2008 | Televison & Video
Fuse locations for RCA Scenium HD65W20
there are 2 fusable devices in this chasis dt307 they are f14200 and f14100 fl200 6 amp 125 v is located Power supply pcb. left rear chasis. f14100 3 amp 125v dm1 power supply pcb left rear. Does the unit have no flashing light... good luck on your troubleshooting and if you need any help contact me via email at the my shop at willie@fordtv.com
Mar 03, 2008 | RCA Scenium HD65W20 65" Rear Projection...
I have an rca scenium
turn off autoformat in customer setup
Feb 25, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Pop and burning smell now no picture
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Jan 03, 2006 | RCA Scenium HD65W20 65" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
77 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
