I have a Memorex MT1701 TV Monitor, screen turns off one second after it comes on. I opened it and I saw two filter caps blown up on the inverter circuit. I replaced them and tried again but it didn't make any change. Any help please? I would like to get the service manual to check around other circuits if is possible.Thank you
  • hitech_repai Jul 12, 2010
    I have a Memorex MT1701 TV Monitor and I can't make stay on, when I hit power sreen goes off right away. I have replaced two filter caps on the inverter circuit were blown up and the inverter IC as well and still there is no defference.Any help please?
  • hitech_repai Jul 13, 2010
    Thank you for all your help, I am really appreciated that I found this site of experts like you guys.
    President:
  • 1,961 Answers
Blown caps destroys other components on the circuit that is why after you replace the capacitor the inverter don't work so better check for open resistors near the capacitors that you have replaced and also the transistors on it.replace any defective resistors and transistors along the pathway of the capacitors.or you can order a new inverter board because the inverter transformer in the circuit might be defective that cause the capacitor to blow..check this link to order a n inverter board.thanx and good luck! hope i helped you
pls rate my help tnx.
Posted on Jul 12, 2010
  • 1 more comment
  • Danilo Baraquiel
    Danilo Baraquiel Jul 12, 2010
    may i add,check also the input voltage which is 24 volts dc input voltage of the inverter board.check the connection the of the voltage supply from the 24v output of power supply..If no voltage is present check the fuses and the power supply itself..
    The power supply it uses is an external PS which is a 12v dc. When I checked voltage on the inverter recieves only about 5v for about one second and then goes off, it is only when the backlihgt comes on. I also checked the PS itself and is working fine.
  • Danilo Baraquiel
    there are instances in a power supply that its supply output is stable but when a load is loaded to the out put of the power supply the voltage output drops! There is a problem on the power supply in this case.2nd is the inverter itself might have a shorted components probably the inverter transformer might have an unstable resistance...better compare the resistance of each transformer...all of them should have equal reading...
  • 505 Answers
This circuit board runs off 24 volts. There is usually a small surface mount fuse on this board, it may have blown when that caps went out. You can check it with an ohm meter, 0 ohms = good, infinite ohms = bad. It will look like this
You can only check it with an ohm/multi meter
If this is not blown, I would check for the 24 volts running to the inverter. If this is not present, check the power supply for issues, if it is present, then it should work. There is also a backlight on signal (usually labeled bl_on or something simmilar) it will be 5 volts telling the backlight to come up. If this is not present, the main board may be an issue.. but all this is rare - you had blown caps, try checking that fuse or 24volts.. if that doesn't get you anywhere, you probably need a new inverter board, these don't go out too often so you can get them quite cheap used on ebay or somewhere on the internet. Let me know what you find, we can fix this. If you don't have an ohm meter, you can buy one at sears or radioshack for like $10-20.
If you don't want to do that, you could just try ordering a new inverter, that would be a high probability of success. Keep in touch, you can get it going!
Posted on Jul 07, 2010
  • thielectronick
    thielectronick Jul 12, 2010
    Is that IC you replaced on the inverter board?
    If so, I would try to get the whole board, look for numbers on it and run them in ebay and google to find a part number.. most of those fail rarely and you can get the board for 20-30$
    Thats my best advise from here..
    you can try to get it to hold on by defeating the shutdown lines or holding up the P_ON line with a 5 volt source from elsewhere, but thats getting into tricky stuff. In theory, you can hold it on and not let it shut down and see if the backlight stays up.
    I've known those transformers to go bad, you can take an O-scope and just put the test lead near (not attached! ) to the output of the transformer. You will see a spike up (this is rf magnetic pick up, remember you're not tapped into the HIGH VOLTAGE, just picking up the magnetic noise) on all the good transformers, but the one that is bad will have a way smaller or non existent magnetic spike. You have to keep trying to kick it on and check each one, but you can narrow it down to a bad transformer this way, then get one from like shopjimmy.com or someplace... but the part will end up costing you most of what you may be able to get the whole board for. Just some ideas, best of luck
When the monitor is turned on the image shows for only 2 seconds and then the screen goes black. This is during boot up and also during operation. During operation, the monitor can be turned off and the...
You may have power supply or backlights inverter problem, or worst case will be the lamps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 30, 2011 | HP Compaq WF1907 Monitor
Desk top appears for short second and then screen goes black, turn off monitor and restart desk top again shows for short second and then goes black. First started in the Windows Live Mail screen.
First, does it do the same when used with another PC?
Pictures: http://s807.photobucket.com/albums/yy352/budm/Acer%20X223W/
You will need to 1) inspect the DC filter caps for any of them with domed tops, 2)then check the DC voltages as shown, 3) You need inverter tester (lamp assemblies to find out if the lamps or the inverter board is bad).
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 08, 2011 | Acer 22" X223w LCD Monitor
My screen lights up for about 2 seconds and turns off How can I make it stay on
It does the same when attached to another PC? Any error message on the screen?
More likely to have power supply/inverter failure. First thing to look for will be the bad DC filter caps with domed tops.
Model ???
Jan 20, 2011 | LG 22" FLATRON LCD Monitor
HP LP1965 monitor appears dead. Green light comes on at bottom of screen but screen does not indicate any activity. Checked with replacement monitor and PC signal is good and responds to all...
More likely to have power supply failure due to bad DC filter caps.
Jan 11, 2011 | HP LP1965 (Black, Silver) Monitor
When i turn on the screen the logo flashes for about 2 seconds then the screen goes black.
This problems is a long board call the LCD inverter board is dead.This long LCD inverter board it help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 01, 2010 | Gateway FPD2485W Television
The Screen comes on for 1 second then goes black but you can still faintly see the image on the screen
It can be as simple as bad DC filter caps (leaking/bulging tops), that will be the first thing to look for, it can be more serious problem in the inverter circuits or bad CCFL assemblies.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 06, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Memorex mlt3221. white screen, no sound, no function.
Check the power supply module for bad DC filter caps first, then check the backlight inverter board for shorts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Parts: www.shopjimmy.com
Please post back what you find.
Jul 29, 2010 | Memorex MLT3221 32 in. LCD TV
Screen comes on then goes off after 5 seconds
You may have power supply DC filter caps problem or the back light inverter circuits, need to inspect the inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 29, 2010 | Proview PL713B 17" Flat Panel LCD Monitor
When powered up,my 2Xgen monitor works for 2.5--3.5 seconds.
Check the power supply for bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 23, 2010 | X2Gen MW22U Monitor
Memorex MT 1701 Screen Problem
ok for those of you having the problem with the memorex mt1701 lcd tv / pc monitor well i had got one of a site call cl anyway when i first turn on it would stay on then turn off all i could here was the sound ok well i figuerd for sume reason the pc mode is the only way to get it to work right!! dont ask me y? but heres how to keep it on and able to watch tv. ok first when you turn the tv on it will go blank after a few when it does on your remote turn it to pc mode that will b the next one after tv you won be able to see if its in pc mode unless you turn the tv on and off a few time but you dont need to do that cuz pc mode is right after tv mode ok so your in pc mode you still wont see anything but what you want to watch for is the the power light it will remaine green for a few seconds than change orange when it does turn off tv than power on in pc mode you will see a no signal sign blinking swithch to the next mode quikly before the light goes orange again after this youll be able to watch tv but keep in mind iv had to youse this methode every once in awile. sumtimes whe id turn the tv of and on it would go to the blank screen again and sumtimes not so i hope i helped sum of you with this problem but thats the way this tv works for sum reason if you have any questions feel free to ask thanks and i hope this help you!!!!!!!!!
Feb 19, 2007 | Memorex MT1701 17 in. HD-Ready LCD...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
