Question about Health & Beauty
Kambrook KHC10B Hair Clipper - (1) how do I fit the blades back together properly and (2) can I get replacement blades?
  • 13 Answers
SOURCE: I have an old Oster
You can get a wide varity of oster clipper heads at Sally's Beauty Supply. I am not sure where you live but they are in most citys.
Posted on Jan 09, 2009
EwingElect
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
  • 7 Answers
SOURCE: blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Posted on Jun 01, 2009
SOURCE: I purchased a Geo Hunter clipper blade sharpener.
hi, not sure of the sharpener you have but to be honest it is very hard to sharpen blades getting the correct hollow grind is essential we receive lots of blades that have been ruined by other sharpening companies.
Posted on Sep 04, 2009
askmannyssha
  • 76 Answers
SOURCE: Need the plastic part on the blade, that are
Call Customer Service at 1-800-326-6247
Posted on Apr 18, 2010
I am recently purchased wahl professional 1124 hair clipper in usa it is is very hard sound. How to less sound
make sure that the clipper blades are properly fitted
they will stand off the clipper body until they line up with the movement
turn on the clippers and gently press down on the blades to ensure full engagement
Apr 25, 2016 | Wahl Health & Beauty
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
Putting back together hair clippers
are u talking about the clipper it self or the clipper blade i need to know which one
Nov 07, 2009 | Health & Beauty
Dont know how to install blade
on blade you will notice two small phillips head screws. remove both screws with thumb on blade. with other hand remove the blade. Blade has two parts. The smaller blade lays on top of the larger blade. align two blades together. Hold the blade compartment in your hand upward with smaller blade on top of the larger blade. On the clipper in between the two hole where screws go there is a small arm with a round shaped tip. Put the base on to the blades a fixing the round shaped arm into the blades ensure proper fitting. With hand holding the clipper turn over while thumb is holding the blades in place and replace screws.
Oct 07, 2009 | Andis 01690 Hair Trimmer
Blade change problem & no info in enclosed instructions
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Health & Beauty Logo
216 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
