Question about GE Refrigerators
WATER IS LEAKING FROM THE BOTTOM OF MY REFRIGERATOR. THERE IS A LIGHT BLUE VALVE OR SORTS, THAT THE WATER SUPPLY LINE FASTENS TOO, WHAT IS THE NAME OF THIS VALVE?
    President:
  • 1,218 Answers
Good day,
It's called a water valve. If the machine has water in the door, it is called a dual water valve, if there is only an ice maker it is called a single water valve.
Water leaking from the bottom of the machine may or may not be related to this valve. The water could be the valve leaking, the fittings connecting to the supply line as well as the lines connecting to the ice maker or water supply system.
If the leak isn't obvious as to where it is coming from, you will need to prop up either the front or back of the machine and using a flashlight or trouble light and try to trace the source of the leak.
Posted on Jul 08, 2010
Troubleshoot SAMSUNG ICEMAKER FOR REFRIGERATOR AND FREEZER UNIT BELOW NEITHER IS FILLING WITH WATER?
do u have a K i N K in hose somewhere do you have water in the line they have that little blue pump make sure you are getting power to it and have a ground ,
Dec 02, 2014 | Samsung RF265AA Bottom Freezer French Door...
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
Have whirlpool gold refrigerator with freezer on top. Water leaking continuously out bottom on floor. I turned water valve behind to off. All leaking stopped. Can someone tell me where to look for the...
One big question before you go hunting. Before you turn off the water, was the water running all the time? Meaning if the water had a continuos flow the leak is before the fridge. If the leak is erratic then its on the valve side to fridge.
Follow the water source in the fridge, supply line to water valve (bottom right behind the fridge), from there it should run straight up the back into the freezer. So, if the water is coming from the valve, replace it, if from the water line - replace it. If the water line came off or out of the freezer reconnect and check for a frozen fill tube.
I hope this information helps.
Oct 21, 2013 | Refrigerators
Fridge is leaking water .... there's a place in the back of the fridge at the bottom (where the water line comes in from the in fridge filter and then goes to the icemaker).... there's two electrical...
yes these are the water valve solenoids and 1 is fir ice maker and the other is for cold water supply in the door,yes just replace it dont even try to fix it
Jan 01, 2011 | Jenn-Air JBL2086HES Bottom Freezer...
Found a leak behind fridge,plastic hose is seperated
There is no connector . The plastic line pushes into the valve . If enough line is there , remove the short piece from the valve by pushing in on the white ring while pulling out on the broken line , and insert the main line into the valve with a little force . Check for leak by using water dispensor.
Aug 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water connection valve at the bottom right back of the refrigerator leaks badly. Water seems to come from the blue plastic cap on the outside of the valve. Where can I get a part to repair this?
You need to reseal the connection. You have to turn the water source to frig of at the tap valve. You then have to loosen the connector for the frig the one that has the vinyl line running thru it. You will get some water out because water from the tap and vinyl line might be under a little pressure. Remove the nut and the vinyl tubing. See if it has a little ring over the tubing. If not slide the nut farther back on the tubing and cut tubing below the nut. reattach the nut to the blue valve, but don't over tighten the nut make it finger tight. open the tap valve slowly. The tubing will get pressure. Look at the connection that you just fastened to see if it is leaking. If it is tighten the nut a little more. This should stop the leak(do not over tighten the nut as this will cause the tubing to leak again. If there are no leaks you can open the tap valve all of the way.
Jul 21, 2009 | GE GTS22KBP Top Freezer Refrigerator
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Leaking water from the ice maker
It is very unlikely that you have a leaking water line inside the fridge/freezer, as they are protected from damage. If you have water dripping from the ice maker inside the freezer and/or the dispenser in the door, the most likely problem is the valve that supplies water to the ice maker.
You'll need to replace the water inlet valve that supplies water to the ice maker. This is not the same valve that supplies water to the fridge (I believe the yellow colored valve) but rather, it is the blue valve, mounted just above the main water inlet valve.
At the bottom back right side of the fridge, you can remove the covering and see both the yellow and blue valves. The yellow one (on the bottom) is the incoming water control valve, while the blue (upper one) supplies water to the ice maker.
The part runs about $45-50 if you get it yourself, or around $185.00 for a repair person to come out and do the job for you. It should only take about 20-30 minutes to do it yourself with a small 1/4" nutdriver. Part available from Searspartsdirect.com or several other online and local stores. Just call around and give them your fridge model number and serial number, located on the inside of the fresh food section of the fridge - on the "ceiling" just inside the door.
Hope that helps.
Apr 08, 2009 | Maytag MZD2766GES Side by Side...
Water leaking from ice maker GE model# TFH22PRS
Hi
Please check to make sure the water tubes are attached properly and are fastened tightly.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 16, 2009 | GE Refrigerators
Refrigerators Logo
286 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
