Question about Olympia Traveller C Typewriter
How do I adjust the keys on an Olympia Socialite manual so they can strike darker letters?
  • Olympia Master
  • 3,594 Answers
This is a manual typewriter, the harder you press the darker the print. You might try a fresh ribbon.
DickyO
Posted on Jul 16, 2010
Where can I find the vertical typebar adjustment?
Guessing the buffer resting stops for smalls and possibly capitals have moved ir come loose? They should be adjustable with a small spanner and screwdriver. Or if not adjustable you might have to slightly slightly bend the resting stops! However before doing any off the a both check the plate under machine where the shift lock rests. That might be very loose abd give some similar problems. Best
Jul 16, 2014 | Olympia Office Equipment & Supplies
Where is the bold key
The 8014S does not have a BOLD key. However, you can do two things to make your print darker:
(1) Set the Impression Control Switch (three dots located above the 10/12/15 selector) to the largest dot.
(2) Turn on double-strike mode by simultaneously pressing the ESC and O keys. (To turn off double-strike mode, simultaneously press the ESC and & keys.)
To find out more about your typewriter, purchase a manual for $10.00 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
May 09, 2014 | Swintec Office Equipment & Supplies
Ribbon doesn't raise up enough to let the letters strike it. Is there an adjustment somewhere?
If it dosen't lift at all wiggle the large black gear bakand forth a few times they do get tooth for tooth.
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
My olympia electric typewriter is always on capital letters no matter how i unlock the keys/shift...won't go back to small letters.
You didn't give a model but there should be a key that says above or on the front of it caps or caps lock the code and that key should do it.
DickyO
Jun 24, 2011 | Olympia Office Equipment & Supplies
Olympia Traveller de Luxe: ribbon not lifting as key strikes.
Hi, The most common cause for this problem is that the colour selection lever is set on white. Try setting it to Black or Red and see if that solves the problem. Ralph, Dial A Ribbon.
Jul 12, 2009 | Olympia Office Equipment & Supplies
Letters aren't striking ribbon
Get some WD40 and spray it on thw segment (the place where the type bars are swung) then everywhere the key mechinism pivots.
DickyO
Apr 04, 2009 | Olivetti Linea 198 Typewriter
Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Aug 21, 2008 | Olympia Mastertype 3 Typewriter
Olympia Traveller C Typewriter Logo
203 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
