Question about GE (PSS26MSRSS) Side by Side Refrigerator
My 1997 side by side GE refrigerator has an automatic ice maker with a metal corkscrew piece to turn the ice that is rusting. How would I clean the rust off of the metal piece?
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
Richie_asg1
  • 1036 Answers
SOURCE: Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Posted on Jun 11, 2008
SOURCE: Refrigerator Ice maker not working
i need an answer to this same question
Posted on Oct 19, 2008
  • 56 Answers
SOURCE: Hello, I have a GE
You can possibly burn out the solenoid valve. There is an off position on the ice maker itself and possibly a switch to turn the power off to the IM.
Posted on Dec 08, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Refrigerator with large puddles of water on floor.
First, your most pressing issue: the water on the floor.
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from coming out the freezer door and leaking onto your floor.
Now, for issue #2, your water dispenser: If you take the front grill off, you will see a plastic tube going through the hinge. There is a coupler, usually a insta-push type just before that. If you push on the collar of the fitting toward the center of the fitting while pulling (not real hard) on the tubing, the tube will come off. Now, try the water dispenser to see of any water comes out the disconnected tube. If yes, comment back to me to see how to fix this, if no water comes out, you most likely have a bad water valve. Reconnect the water line by just pushing it back into the fitting. Disconnect the outlet side of the water line at the water valve and try the dispenser again. No water out the valve almost always will be a bad valve. (there are rare exceptions) Water out valve now when dispenser is pressed equals a frozen water tank or water filter in the fresh foods compartment. Issue #3, your uncovered foods: All the cooling for a refrigerator takes place in the freezer compartment, and some of the cold air is circulated into the fresh foods compartment to cool it. As the air is circulated throughout the entire refrig / freezer, air picks up and transfers odors to uncovered items, including ice. Cover foods and use an open box of baking soda to help absorb odors. Issue #4. (was there a #4?) Oh yes,..... why are you dealing with this? Tell the landlord to have a service company come and check it out. You don't pay the service company, you pay the rent. Landlord is responsible for the repairs.
Posted on May 17, 2009
Our ice maker has rust on ice sometimes and can't understand why or how to fix
You would need to remove the ice storage bucket and dump the ice, check the corkscrew wire in the bucket for any signs of rust, some auger wires were chrome plated and not aluminum. If no rust there, remove the ice maker it's self and check the ice making mold for signs of rust. Replace all rusted parts found. Pleazer Appliance...
May 06, 2014 | Frigidaire GLRS237ZA Side by Side...
Trouble with crushed ice function on ge profile fridge
Replace the bin. I think if you inspect it, you will find some plastic broke off of it.
Aug 18, 2012 | GE Refrigerators
I have a GSS25WGTA GE ice maker. The arm on the ice maker won't reset after it dumps ice. I have to manually do it every time. Is there an inexpensive fix for this?
If you find a way to add a weight to the arm to make it drop down it cheap. what may work is a peice of metal attached to arm.IT MUST be stainless steel so it doesnt rust in the freezer with all the moisture then all your ice has rust in it
other than that icemaker has to be replaced
Aug 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
How can I stop automatic ice maker from continually making ice?
There should be a metal wire that hangs over the drawer. When the drawer is full, the wire flips up and shuts off the ice maker. You have to manually lower the wire back down to restart the ice maker. It sounds like yours is hung up, missing or broken. Have you checked this?
May 08, 2010 | GE GSS22IFR Side by Side Refrigerator
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
I need an ice maker for my GE refrigerator, made in the 70's
PART NUMBER IS WR30X10093 @ $148.00 available from AP Wagner or Marcone appliance parts
Apr 09, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Automatic ice maker will not dipense ice cubes.
This may be a circuit board problem for which there might be a recall from GE. I had the same problem and found information about it on the web site below.
http://applianceguru.com/view_topic.php?id=13243&forum_id=1
Feb 19, 2009 | GE Profile PSS26NGS Side by Side...
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
Jan 24, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Refrigerator/FREEZER
The problem was solve but not by turning upside down.
Jul 19, 2008 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
175 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
