Question about GE T28821FE2 19 GHz Twin 1Line Cordless Phone
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
  • GE Master
  • 5,126 Answers
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Posted on Jul 08, 2010
I have just purchased a phone plugged it all in have you to wait till batterys have charged for it to work
Usually you need to wait about 15 hours for the new phone batteries to charge up.
Oct 02, 2016 | Lands Phones
What to do if my phone stops charging
batteries might be old. If you have another phone unplug batteries from there and plug them into the non charging phone. It it charges, get a new set of batteries
Jul 10, 2014 | Alcatel Cell Phones
Not ringing on incoming calls
if the ph has stopped altogether then it is probably the battery as most batteries for phones that go under 25% charge can not be revitalised. Find a new battery on EBay is best. ps they may seem to be charging but are not. Cheers
Jul 29, 2012 | Lands Phones
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Just bought new battery, need toknow how to get phone to work again
When you get new batteries for a cordless phone you need to let them charge over night. If you don't the battery will lose its charge much quicker. Now start by charging the batteries followed my plugging the base unit into the phone jack and the electrical outlet. The base unit is what sends out the signals to all the phones and is where your answering machine is located. Once the base is plugged in to the electrical socket and phone jack your phones should start receiving signal again. Make sure the batteries in the phones themselves are plugged in firmly and properly.
Feb 28, 2011 | Uniden DECT15805 Cordless Phone
Hi, my wife's Sterling Melody powered wheelchair appears to have developed a fault. Plug it in to charge it seems to be ok, the VR2 controller seems to be indicating it's charging after a few hours when...
Leo Man you need new batteries. No amount of charging will recover those batteries. The reason you have power when charging is because of the charger suppling the power to the chair and when you unplug it you have no stored voltage in the batteries to power the chair. If Medicare paid for the wife's chair contact your provider or a service company to install new batteries in her chair. Medicare will pay for most of the repair cost. Hope this helps you Good Luck
Nov 13, 2010 | Health & Beauty
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
Battery won't charge in phone.
Have you tried a different charger? If not I would suggest stopping by one of your cellular providers stores and having them plug it in to see if it works.
Mar 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
GE T28821FE2 19 GHz Twin 1Line Cordless Phone Logo
200 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
