Question about Kenmore Washing Machines
Clothes have dark streaks after washing this is a kenmore front loading washer model number 417.42142100
    Top Expert:
  • Kenmore Master
  • 76,630 Answers
I read post after post about this very same problem, it is caused by a failure of the bearing that the tub rides on, this causes the grease seal to leak and then the streaks which are grease stains from the rear bearing
Posted on Jul 07, 2010
  • washingblues Nov 28, 2010
    How much should it cost to have this repaired?
  • yadayada
    yadayada Nov 28, 2010
    Around $400-450
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Kenmore washer leaves dark streaks on light colored clothes
I suggest you first take a clean, white cloth wetted with a stronger solvent such as 'Oops,' carburator or brake cleaner (with these two, DON"T overspray, they will damage plastic and paint) and wipe the drum inside to make sure there is not some gunk adhering that is gradually depositing itself with each wash cycle.
If you have a shade-tree mechanic in the family, they may have gotten a gob of grease on clothing that transfered to the inside of your machine.
If you don't find enough on the cloth to have caused the problem, I think you have lost a seal on the drum-side of the transmission.
Posted on Jul 01, 2008
White streaks on dark clothes
The white streaks are of soap build up on your machine tub. You can get ried of that by putting cascade dish washing soap in your washing machine and run full cylece , with out clothes.
Apr 13, 2013 | LG WT4801CW 3.7 cu. ft. top load washer
Kenmore model 24054 washer that leaves dark streaks on clothes.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to access the console, pull the cabinet, agitator(s) and tub if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=ef7d852e2285d2944a8b015a847b15db
You don't have to pull the pump, motor, transmission and drive tube to pull the agitator and tub.
HOWEVER:
A number of the diagnostics and repair procedures for these washers require you to remove the agitator(s).
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut. However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner
nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
With the agitators and tub out, it's relatively easy to clean out the gunk that builds up over time.
Apr 25, 2010 | Kenmore 24052 Top Load Washer
My front load kenmore leaves faint dark streaks in
look carefully inside the tub, gasket, lid. There may be some debris of some sort stuck somewhere causing this problem.
Then run the machine adding only two cups of vinegar. this will clean it.
Aug 20, 2009 | Washing Machines
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
White streaks on dark clothes after washing.
Reduce the load !!
You are getting white streaks because the clothes are so compressed the machine is not agitating them correctly.
My daughter gets the same problem and she still insists on packing the clothes in.
My wife washes the same clothes for her with the right load and they come out fine
Jun 18, 2009 | AEG Lavamat 88840 Front Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF1240AS0-%3d%3di407639&PartID=407639
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
Jul 01, 2008 | Kenmore 43042 Front Load Washer
Washing Machines Logo
203 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
