Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
After pressing the start button the washing light flashes and the heated dry light is on like normal. However the wash cycle never starts. Is there a way to reset the computer or do I have to replace the controller board?
  • 10 more comments
  • Anonymous Apr 25, 2008
    Same problem - wash light just blinks won't start.
  • Anonymous May 16, 2008
    same problem here . mines black instead of stainless
  • brodriguezrn May 26, 2008
    Same problem but I have water that will not drain either. Can someone help?
  • Anonymous Jun 05, 2008
  • joanne226 Oct 30, 2008
    Same issue but your solutions didn't work. Help!
  • pwilliestyle Oct 31, 2008
    I had the same problem, and the running hot water in sink fixed it. Not sure why.
    Thanks!
  • Anonymous Nov 23, 2008
    We have the same problem. I have tried all the solutions suggested and still get the same dang blinking light
  • edfreimuth Dec 28, 2008
    kenmore elite dishwasher doesn't drain all the warter out
  • jennygee Jan 05, 2009
    Same exact problem. Dishwasher is less than one year old. Turned to different setting and back to normal, but didn't help.
  • collinsm Jan 15, 2009
    heated dry light is on like normal. However the wash cycle never starts. When I change to a different cycle the heat light comes on and then goes off when the cycle is changed back to normal. I turned the water source off and back on and it started working, but after a few washes it doing the same thing.
  • Anonymous Mar 28, 2009
    I have a different Frigidaire brand but it does the same thing.
  • Vaughn Salamy Jan 28, 2013
    PLEASE READ before replacing board. I fixed mine this morning in about 15 minutes by reading this site and then removing 8 screws from the dishwasher to remove front panel. Double checked latch connections, then pressed button after latching door and everything worked. Wow, that was free and easy! Hardest part was getting the panel back on. So, here is what I recommend. Do not remove 8 screws, leave the lower 2 in the panel to keep it in place. The 6 screws at the top are the ones that release the control panel, and maybe only need to remove 4. Double check this by removing the 4 screws along the top of dishwasher door first, then if the control panel slides out good. Simply check the connection that go to the latch mechanism, then try the controls. Hope it works for you as well as it did for me!
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
Posted on Feb 21, 2010
  • chuck99 Aug 09, 2010
    great help!! It worked immediately!
    thanks!!
Try running the hot water in your kitchen sink until the dishwasher kicks on.
Posted on Sep 16, 2008
Press normal then heated dry
Three times in a row.
After the 3rd time all lights will go on. then press start .
Posted on Jan 12, 2009
I unplugged it and then plugged it back in and it worked, Whew! Didn't want to wash all those dished by hand!
Posted on Mar 02, 2010
    New Friend:
After trying all these solutions (to no avail), I got frustrated and banged on the door near the latch. Bingo, it started! When all else fails, a little tough love might just do the trick.
Posted on Mar 30, 2013
  • jharris34
    jharris34 Mar 30, 2013
  • lida
    lida Mar 13, 2015
    i love you!!! it worked!!! tough love go figure lolll
Simply turn the dial to another setting for a moment, turn the dail back to the Normal Wash and then press start again. Repeat the process with a different setting if it doesn't work the first time. This is what worked for me. Good Luck
Posted on Jul 01, 2008
Reading your posts helped me to develop my own simple test. I became suspicious of the latch so I opened the door and hit the start an got identical results. Unfortunately I already replaced the panel (bad guess). So with the panel hanging from the plug I reached in and pushed on the connectors to the latch and it started. For now I have a piece of foam wedged in between them and is running as I post. I will replace the latch later. Ps dont touch any copper portion of the connector.
Posted on Feb 26, 2012
  • Debra Mullen Sep 09, 2012
    Our 3 1/2 yr old frigidaire dishwasher suddenly wouldn't start last weekend, start button flashing , but nothing else, we went online and figured it must be the control module, ordered one from sears parts, got it on Thursday, plugged it in and no change. Just found this website, played with the loose door latch plug and its now working!! Thanks for your help!!
Alright. I unplugged mine, waited 30 seconds and plugged it back in and turned the knob to rinse only and held the high temp and start buttons for ten seconds to start the maintenance mode and nothing happened. I replaced the control module and it started but then stopped and light was blinking again. After thinking, I'm gonna throw this piece of junk to the curb, I tried unplugging, then removed the connector, then messed with the door latch switch, and finally put back together and started...after a lengthy pause it started. Ok, 5 seconds. But hoorah...for now. Other posts indicated changing the control module only lasted for a short while. Some days, some months. To the curb it still may go.
Posted on Sep 08, 2012
I had to unplug the dishwasher to reset the computer and it worked fine after that.
Posted on Oct 29, 2008
Whoa... Mine was doing the same thing! It was an easy fix!
1. Remove the control panel cover2. Disconnect the control harness from the washer3. Reconnect the control harness--- *NOTE* All lights will begin to blink ---4. Test the system by closing the door and pressing, "WASH"--- *NOTE* System should have reset itself and now run properly ---5. Reassemble the control panel cover
It took me a while to figure this out because i was so focused on trying to figure out why the "latching sensor" wasnt working..
Posted on Jan 08, 2012
2 Suggested Answers
SOURCE: Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
Posted on Mar 28, 2009
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Kenmore Ultra Wash Model 665.1388 problem the normal wash green light is on heated dry light is on and the start resume light is flashing but wont startup helpppp
see your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free www.retrevo.com or www.fitness.manualsonline.com
see the diagram
God bless you
Jun 18, 2012 | Kenmore Dishwashers
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher lights blinking
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
16,974 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
