Question about RCA F19207BC TV
Does the RCA model #F19207BC connect to a dvd/vcr player?
I used my tv only with cable connected for many years. When I upgraded to a digital i sat this tv away. Now I would like to pull it out and use it as a stand alone dvd/vcr player tv and not have it connected to cable. Does this model have the capabilities to connect to a dvd/vcr player? I only see a plug that says antenna and one marked with an F and one marked S. Nothing that reads video in/out.
  • RCA Master
  • 10,291 Answers
Nope. No external jacks for video and audio. You can use the antenna connection with the dvd /vcr player by connecting the antenna out on the player with a suitable length of coaxial cable with F connectors on both ends. Then you would locate the channel 3/4 switch on the player and choose either one. On the TV you would put the same channel on the TV tuner that matches the player channel and you will see the picture.
Posted on Aug 16, 2017
2 Suggested Answers
  • 5418 Answers
SOURCE: Looking for tv manual for RCA XL100 F19207BC
I found two different manuals for the RCA XL100 F19207BC using the RCA manual search (http://www.rca.com/tvsupport/tv_manual_search.php ) The direct links are: http://download.rca.com/FilesForRCAcom/Manuals/1512765B.pdf and http://download.rca.com/FilesForRCAcom/Manuals/15127650.pdf .
I hope this helps.
Posted on May 22, 2011
I just bought a digital video disc player & video cassette recorder. I'm having a problem connecting the player to my TV. My model No.is DVP3345VB/F7. Where I'm having a problem is the cable source...
You now connect the cable and the combo directly to the tv by using different connections: the cable goes in the antenna entry and the combo is connected to the tv with a 3-headed RCA cable - with heads of Yellow, Red and White.
Then when you want to see one or the other you just select the appropriate source from the tv's menu using the Source/square with arrow in it/AV or whatever is called in your model button on the remote.
Nov 04, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a dvd/vcr that does not have a coaxial cable hookup on back of vcr. I need to have my satellite hooked up
If your VCR does not have the coax connection then you should either have RCA inputs and outputs or the BNC type of connections. If you have the RCA style then you can connect your sattelite receiver using them. If you have the BNC type then you may have to contact the manufacturer to see if there are converters available to switch your RCA ends to BNC. You will also have to find out if the BNC connections will even work with the outputs from the satellite receiver.
Feb 02, 2010 | Televison & Video
Blue screen. No audio or video through the cable hook up. RCA model #32V420T
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Oct 25, 2009 | RCA 27F534T TV
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a new 52" Samsung HD TV with a new Sony Blue Ray player and a Shaw PVR cable box all connected with HDMI cabes. I also have a older digital RCA model RTDVD1 sound system with no HDMI connection and...
I have the same situation....what I have done is connected my Blue ray to the TV via the HDMI connection and the audio to the RTDVD1 via an Optical cable. I find this is the best connection and sound reproduction so far. The input of the RTDVD is the SAT/Optical input and then switch the source to SAT/OPT. You will have to make adjustments in the BlueRay player's audio setup to enable the 5.1 DB digital sound etc.
Jan 24, 2009 | RCA RTDVD1 System
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
RCA F19207BC TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
