Question about Linksys EtherFast 3116 Networking Switch
How can i reset the linksys ef3116 to default if it doesn not have a reset button or knowing what the ip address is on the switch?
    Problem Solver:
  • 5 Answers
You can use a port scanner to find its IP address, such as Angry IP Scanner http://www.angryip.org/w/Download and reset it from there. It is most likely 192.168.1.x or 10.0.0.x.
Posted on Jul 07, 2010
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
Sep 07, 2011 | Computers & Internet
I have a linksys router and i have tried to access the configuration menu. I have tried the common 192.168.1.1 with no sucess. i have even looked at my details for the ip and it is 192.168.24.1. That does...
Resetting by pressing the button for a total of sixty seconds usually works! While holding the button you can also power cycle the router once or twice. That should put the router back to default settings. Its frustrating sometimes but usually works by prolonged resetting and power cycle. Good luck!
Sep 06, 2011 | Computers & Internet
WRT300N: does not boot, all leds are lit
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Apr 10, 2011 | Linksys WRT300N Wireless Router
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
If you forgot the router's IP address you can:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
MY LINKSYS WRT54G2 IS OK BUT CAN'T FIND SERVER.
The Linksys WRT54G2 is Cable/DSL router with 4 port switch. It has many features including a built-in DHCP server. By default, it's IP address is 192.168.1.1, username: blank and password: admin.
Plug in the Modem to the Linksys router's Internet / WAN port then plug your PC's to any of the 4 ports (1,2,3 & 4). The Linksys router once turned ON will automatically provide your PC with IP address starting with 192.168.1.xx (x means number from 100-149).
Make sure that known working ethernet cables are being used. Check your computer's IP adress by going to the command prompt. Start>RUN>type CMD then press Enter. Type IPCONFIG and check the IP address (e.g. 192.168.1.100). Check you PC's network adapter if you don't get an IP address from the Linksys router.
You may opt to reset the router by pressing the reset button at the back for 30 seconds if it fails to give out DHCP.
Cheers!
Angel
Jun 22, 2010 | Linksys WRT54G2 Wireless Router
How can I put a code on my linksys?
Open Internet Explorer.
Type 'http://192.168.0.1' (or try 'http://192.168.1.1').
This will connect to the built-in web-server inside the Linksys router.
Click to run the 'Wireless Networking Setup Wizard',
and choose an SSID and choose a password-code.
Dec 29, 2009 | Linksys Wireless-G Broadband Router
Reseting without the button
192.168.1.1 default IP address unless you change it before....to verify the IP on your router ...right click on network icon or adapter icon ...select status...then DETAILS...the Default gateway is your routers IP
Apr 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys EtherFast 3116 Networking Switch Logo
277 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
