Question about Gateway M305CRV Notebook
Dark screen with flashing dash in upper left corner. No start up or desk top.
  • 10,319 Answers
Start it up and keep pressing the key F8
You should get a repair screen to show. If not the hard drive is completely shot
Posted on Jul 07, 2010
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
Nov 26, 2012 | Televison & Video
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 08, 2011 | Computers & Internet
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
After trying to change the resolution on my monitor to maximum screen resolution it has just gone blank. the start up menu works ok but then when desk top and start menus should come on the screen is...
Move the mouse so it is way, way down in the lower right corner. Place a penny or dime on the mousepad touching the upper left corner of the mouse. Pull the mouse diagonally down to the right a distance equal to the diameter of the coin. Then back up to the coin.
Right Click
Take your hand off the mouse because the rest is on the keyboard.
up <arrow>
<Enter>
hold <Shift> press <Tab>
right <Arrow> 10 times.
<Tab>
left <arrow> (decreases resolution, right arrow to increase)
<Enter>
By the by if you can find a monitor that will accept the resolution you selected on the 'Properties' window you can switch it back the normal way
Aug 04, 2009 | HP Pavilion F1523 15" LCD Monitor
Black screen with flashing small line in upper left corner
PULL OUT THE MEMORY AND PUT THE OLD ONE BACK IN AND SEE IF YOU FIX THE PROBLEM.
Feb 12, 2009 | HP Compaq d530 SFF PC Desktop
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Gateway M305CRV Notebook Logo
87 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
