Question about Toshiba 50H81 50" Rear Projection Television
Needs a slight realignment on the red bulb
There is a pink outline around writing and such like a mirror the red outline appears to me a few millimetres down and to the right the other two bulbs are fine advice on how to aligne without the price of a pro?
  • Toshiba Master
  • 8,457 Answers
The colors R,G,B out of alignment does not matter how much,any millimeters.The tv are having a convergence problems and will get worse.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be change to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
Posted on Jul 07, 2010
  • Toshiba Master
  • 3,459 Answers
READ THIS ARTICLE ON FIXA TO ALIGN THE CONVERGENCE
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 25, 2011
INTERNAL TEMPERATURE FOR BEEF
it all depend how you want your Beef
Rare:
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
Medium-rare:
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
Well-done:
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
Thereis a red outline around the subjects on my bush TV
the antenna in god direction?
open tvbehind cover,,,,,,thir is 3 rings around crt neck,,,every one for adjusting one cplour[R,G,B]ROTATE THE R ONE WHILE WATCHING,THROUGH A MIRROR,,,,,,YOU MUST ADJUST FOCUS FIRST,,,,,,,for tech it will be easy by using battern generator
Jan 07, 2011 | Bush WS6671 28" TV
Red /yellow cloured oil leak around behind front wheel line
if it is yellow it could be the aircon compressor, if it is really red to pink, power steering or automatic transmission leak
Jan 08, 2010 | 1997 Mercedes-Benz E-Class
My projector has a green/red ghosting around all images- just replaced the bulb- have tried s video and R/B/G video cables and does it on both- any suggestions as to what is wrong?
reset the settings to factory default. could be lack of resolution matching. as for physically, the mirrors in the optical engine need realignment. very long and difficult job.
Aug 15, 2009 | Sanyo PLV 60HT Multimedia Projector
Sony KDP57WS550 Projection tv red, green and blue virtical outlines on left and right sides
This is a convergence problem. You will need the stk's changed and a pico fuse or 2. also from looking at the pic you might want to clean the lenses and mirror after the repair to bring back some of the vibrant colors the set once had when it was new. This repair should run you anywhere from $300-$500 depending on your area and the tech that comes out. If you need more information or would like to try to fix it on your own please let me know.
Tim
Sep 10, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Pink and Blue Spots
Sony guarantee the consumer to replace the optical block assembly for thousands of dollars in parts and labor every four years or when the pink and blue spots appear every time. Then replace the optical block assembly again and again every time the spots appear.
Aug 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
LP690 projector displaying strange lines
to adjust those mirrors, you need to power down, unplug, remove the top, remove the wires from the main board, remove the main board, adjust one mirror, reinstall everything, power up, see whatever difference it made, power down and repeat until it's fixed. it's quite a chore. if that's not the problem, you'll need to replace the optical engine (which isn't cheap) because they don't sell individual parts.
Mar 09, 2008 | InFocus LP690 Projector, Factory...
Red and Blue Shadows
There is no alignment of the lens because the optical lens is fixed. If he removed the lcd panels then there may be a problem. You may want to check to make sure there is nothing on top of the optical lens or the mirror inside the mirror block assy wasn't damaged. If he damged the optical block or lcd panels then an optical block may need to be replaced. Very costly. Good Luck
Sep 18, 2007 | Sony KDF-E55A20 55 in. LCD Television
Neon Pink outlines around bright images
two points one green and another pink one in the screen Panasonic PT-61LCX65
Jan 30, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
327 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
