Question about Kenmore Sewing Machines
Bobbin tread is loose when sewing on cotton material Have adjusted tension, it is on 9. It is fine when I sew denim, which I sew a lot but I am trying to sew cotton now. I have cleanned machine, changed needle. Can't seem to figure this out.
    Problem Solver:
  • 6 Answers
Have you checked not only the top tension but also the bottom (bobbin) tension? Top tension is usually a lever wheel etc on the machine (depending on model). To tighten the bobbin tension you need to tighten the small screw on your bobbin casing.
I don't suppose it could be as simple as this?
Posted on Jul 20, 2010
Needle stitch fine. Bobbin stitch loops.
First, try a brand new needle.
Second, consider using a better quality thread. By all means, AVOID old or bargain bin threads. Coats & Clark used to be a standard, but thread quality has improved over the past few years, so you may want to check out other brands like Aurafil, Superior, Isacord, etc. Also, cotton wrapped polyester thread releases thread lint that contributes to build-up of gunk in the machine. Some sewists have noted that they experience more sewing issues when using C&C threads. However, some machines will do better with certain thread brands than others, so some experimentation may be beneficial.
Third, check the stitch on your sample again. Generally, when thread loops appear on the underside of the fabric, it is the upper thread that is the problem. If loopy threads appear on the top of the fabric, it is the bobbin thread that is the issue. You can even use a different color in the top to help distinguish which thread is the problem.
Fourth, when threading the upper thread, Always Raise the Presser Foot during the threading process so the tension disk is released and the thread can seat properly. "Bird nesting" occurs when the thread is not seated in the tension disk.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Fifth, when the upper thread appears on the underside of the fabric, the upper thread tension is too loose. If the bobbin thread appears on the top of the fabric, the tension thread is too tight (or the bobbin thread is loose). Start out with the upper tension set at the midway point and tweak it from that point. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Also, remember that tension is not static--a tension setting for chiffon will most likely not work on cotton or denim. Get comfortable adjusting the tension to suit the project you are sewing.
May 24, 2016 | Sewing Machines
How do you adjust the bobbin tension?
Factory standard tension for upper thread is the midway point between the high and low number. However, that tension dial is meant to be used for tweaking tension. Generally, tweaking is required whenever the type of fabric, needle, or thread are changed, ie thicker fabric like denim should have a different upper tension setting than fine chiffon. To be successful with tension settings, one must become comfortable adjusting the upper tension.
NOTE: Accurate tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric.
Understanding Bobbin Tension
Jan 20, 2016 | Brother Sewing Machine - XL2600i
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Hello
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
I am sewing a cotton piece of fabric for a dress and i do not know how to set the tension for cotton
The tension for cotton is set the same way tension is set for any fabric:
1. The thread should pull freely with a small resistance before/after it goes through the needle, on many machines that's half way on the tension adjustment.
2. The bobbin thread when dangled by the thread with the bobbin inside the case should drop down a bit when slightly flicking your wrist like you do with a yo-yo. If it reels out to the floor the tension is too loose. If it doesn't drop at all it is too tight.
3. Now make sure you use the right type of needle. For cotton you want a "sharp" and for reg. weight cotton about a size 10 maybe 12.
Now take a piece of strap cotton material like you're going to sew a seem and sew with a wide zig zag. Example the top side and then the bottom. They should appear identical, flat with needle holes at each side where the thread disappears to the other side. You should see no loop where the threads over lap each other and the material should not be puckering in the middle.
If that is not what you see then think this way:
The TOP side of the stitch is effected by the BOTTOM thread. the bobbin tension.
The BOTTOM side of the stitch is effected by the TOP /needle tension.
Adjust the responding tensions until the stitch looks the same on both sides. Now you are ready to sew your cotton! :)
Apr 26, 2011 | White Sewing Sewing Machines
My bobbin stitch is loose. I have tried adjusting tension and have changed the needle.
A. To correct loose stitches, try the following: (1) Balance the thread tension. If the stitches are loose on top of the fabric, decrease the tension to the next lower number. If they are loose on the underside set the tension to the next higher number. (2) Make sure the needle/upper thread follows the threading path. (3) Check to see that the bobbin case is threaded properly. (4) Use a different size needle. For fine fabrics, use a smaller needle (size 9, 11); medium-weight fabrics require a size 14 or 16. And use a size 18 or "Denim" needle for heavy corduroy or denim.
Sep 20, 2010 | Singer Curvy 8770 Electronic Sewing...
Sears Kenmore Sewing machine model 15358 Just got this machine brand new yesterday. I've gone through the manual very carefully to make sure the machine is threaded properly. It's very similiar to my old...
The tensions must match ie. top tension =bottom tension. If the material is not sewn together tightly, that means the tensions are mismatched. Sewing machines will sew whenever the top and bottom tensions are equal (be it very tight or very loose).
We usually advise the customer to not touch the bobbin case tension. When that is not changed, all tension adjustments can be made from the top tension above the needle.
It appears that one of the two tensions (top or bottom) is much tighter then the other. I would reset the tensions to how they came, if you are unfamiliar with sewing machines this may take a little bit of experimenting until you get it back to a standard quality stitch.
The other option would be bring it to a sewing tech. A good mechanic should be able to adjust the machine and your tensions to your fabric (and recommend needle size for your thread/materials) in about an hour.
Apr 15, 2009 | Kenmore 15358
Sears Kenmore sewing machine model number 15358 tension issues
#14 needle is way big for cotton napkin scrap. a #10 is good for most lightweight fabric. #14 is for sewing denim or levis, like that.
the tension problems on almost all machines regardless of price usually fall on the upper tension. the lower bobbin tension is factory set and it's rare you should ever need to mess with it.
if you have a drop in bobbin (top loading), tighten the adjustment screw all the way and then back it off 1/4 turn. if your machine uses a shuttle bobbin, tighten the adjustment screw all the way and then back it off in 1/4-turn increments until you can hold it in the air like a yo-yo and cause to bobbin case to fall slightly dipping your hand.
A dull needle and stitch length will also mess up your stitch. The idea is to narrow the problem down to one thing and one thing only -- UPPER THREAD TENSION.
So, if you have the right size needle for the job, with the right thread, and if your stitch length selection is correct (usually between 2 and 3 or 8-to-10 stitches per inch, the problem should be with your upper thread tension.
An easy way to fix this then is to remember: Loops on top, upper tension drop. Loops below, upper tension grow. If you get loops on top of your work, lower (drop) your upper thread tension to a lower number. If you get loops on the bottom, raise the upper thread tension.
Different stitches on the same machine will require different upper thread tension settings. Don't be afraid of it. Just remember the pneumonic: loops on top, tension drop, loops below, tension grow -- referring to upper thread tension.
have fun :)
Apr 15, 2009 | Sewing Machines
Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Nov 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
90 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
