Question about Kenmore Oasis HE 27082 Top Load Washer
Hello my name is Karina Alvarez I have a kenmore elite oasis he washer machine and is show in me a F error what that mean?
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
When I start my Kenmore Elite Oaisis HE washer, I keep getting an error, "F1". What does this mean?
Hello & Welcome to FixYa
Error Code F1 means that the control is either bad or the wiring harness to the control has some issues. Please check the control board for any bad components as you might need complete replacement of the control. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does code F1 mean for a Kenmore Elite Oasis model 27032?
Here is a link to some good information on your error code. This should explain the error code you have.
http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
Nov 21, 2010 | Kenmore 27032
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
701 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
