Question about Bosch 24 in. SHU43 Built-in Dishwasher
Fon the dishwasher
My Bosch dishwasher model BF71 has suddenly stopped working and has an F on the control panel.
Please tell me what this means?
L
  • Bosch Master
  • 2,605 Answers
Hi, welcome to Fixya.
Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the Bosch machines.
Here's how to perform a test or diagnostic...
Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ).
Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ).
When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time.
Let the test follow through, ( grab a coffee and observe, this will take a while )
When testing has ended, the display will show an error using codes as follows...
"0" = no error.
"1" = aqua sensor fault.
"2" = heating fault.
"4" = filling fault. and finally.
"8" = NTC ( temperature sensor ) fault.
The "F" code will not appear in test mode, only during wash. If you have a failed level switch for instance the test will display "4" and will continually fill and drain and test won't complete until you press the "on/off" button.
If the test complete's without and error or won't fill, replace the water valve. Original part Part # 425458 at "searspartsdirect.com", "apwagner.com" or #1105846 at "repairclinic.com" ( they use there own numbers ) or you can check locally by your model number & serial number.
Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating.
Thank you for choosing "fixya" and good luck.
macmarkus :)
Posted on Jul 08, 2010
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Dishwasher LED not lighting and dishes not cleaned
If it's making a sound, that means you have power. You may need a control board or a console or both. Check the ribbon cable between the console and the control board for any loose connections. If everything is fine, replace the parts.
Mar 12, 2014 | Bosch SHU33A05UC Stainless Steel...
I have a Bosch dishwasher Model SHE58C05. This model has two displays, one on the front where you can see and one with the hidden controls that you can't see when the dishwasher is closed. The display in...
If you check your user manual there is a section that will guide you through turning off/on the display screen. I have tried to include the link for Bosch manual downloader but their site is down at the moment. If you do not have your manual and therefore cannot rectify the fault, please repost or comment on this solution and hopefully the site will be back on and I can reply with the link.
All the best
Aug 12, 2010 | Dishwashers
I have a bosch dishwasher model classxx maxx freedom performance sgs43co2gb/35. the machine when turned on doesnt stop,so i checked the control panel and there was a black ring of soot,before i purchase a...
i think your model was part of the recall and the repair is free to fix call bosch and they will take of ity. they need to know the model asnd serial number to know if it is one of the recall
Mar 08, 2010 | Bosch Dishwashers
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
One year old Bosch dishwasher stop wrking.will not
Start with the basics: Check the status of the breaker and the electrical connections under the toe kick panel. If the unitis getting power, You may want to call the dishwasher helpline to see if it is a recalled model. A free replacement of the control panel circuit board is available for many of these, but if the power switch is the culprit, you will need to buy a replacement button.
I have written a guide to help with drainage issues. The helpline number is near the top. It is here. Thanks!
Jul 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I cannot be sure of the make/model - there is no power
It sounds like you have a bad controller which is an expensive part if it is over five years old. However, there is a recall on some Bosch dishwashers which involves replacing the control. If you call Bosch at 1-800-944-2904 they can tell you if your model is involved in the recall.
Apr 17, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Hotpoint Ultima BF71 Dishwasher 'F' code
clean out all the filters at the bottom of the dishwasher thorouly and the saltcontainer as well.
the f code is for filters.
Nov 16, 2008 | Hotpoint 24 in. BF72 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
445 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
