Question about Frigidaire Heating & Cooling
Have an FS3BC-036K fedders central a/c unit. is
Have an FS3BC-036K frigidaire central a/c unit. is there any way to increase the output to 3.5 tons?
Agent Dort
  • 216 Answers
SOURCE: size
Greetings jdreisbaugh,
The tonnage is usually found on the name plate on the condensing unit outside. 12000 btu = 1 ton, 24000 = 2 ton and so forth. In your case the unit is 36000 btu, therefore a 3 ton.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jul 24, 2008
  • 340 Answers
SOURCE: ge central air conditioner model #bgwa86or1b bad compressor
model and serial number
Posted on Jun 26, 2009
  • 674 Answers
SOURCE: frigidaire central unit freezing up leaking
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Posted on Jun 06, 2010
dhj144
  • 80 Answers
SOURCE: unit not cooling
Low on refrigerant charge! Low side line should be cold like a beer can at the inlet of the compressor with some sweat beads around it. 55deg. The discharge should be around 125deg just hot enough you cant hold it long!
Posted on Aug 29, 2010
shastalaker7
  • 1515 Answers
SOURCE: Recently replaced entire central a/c
Hi, 2,500 ton unit would be the size of a 15,000sq.foot warehouse! I think you mean a 2 1/2 ton Rheem condenser. You could run an add under Craigs list.com, and if the unit is in good shape, I would ask no more then $600 for it. As a Contractor, I can get them anytime new for around $660.00. If you can get $500 for it jump on it. Best of luck to you,
Shastalaker7
A/C Contractor
Posted on Jul 26, 2011
Testimonial: "Thank you for your quick response...you were right it is a 2.5 ton unit...see how much I know about this stuff...Thanks again!!!!"
I have a older Fedders unit model number CRB120CNA what is the tonnage of this unit
I don't believe you have copied that number correctly.Look for a serial number. Is this a window unit?
Jun 27, 2017 | Fedders Heating & Cooling
How do I fix my Frigidaire A/C unit Model FS3BC-036KA (3.0T)
You are low on refrigerant. You need to find a service location that can recharge it for you.
May 08, 2015 | Frigidaire Heating & Cooling
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
WHAT SIZE IS HEAT PUMP Q3RA-036K
Hello, this is a 3 ton unit. There are 12,000 btu per ton. The number 36 in the model number represents rhe tonnage of the heat pump, so 12,000 x 3 = 36,000 which is 3 tons.
May 09, 2012 | Heating & Cooling
No problem trying to find out tonnage i would like to know how big a unit i will need when i replace this
This unit is a 3 ton unit
P3RA-10 SEER
3, 4 and 5 Ton Units
Cooling: 32,500 to 55,700 Btuh
P3RA- Cooling Btuh SEER
036K 32,500 10
048K 45,500 10
060K 55,700 10
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 09, 2011 | Intertherm P3RA-036K Air Conditioner
What is the tonnage on an Intertherm S3RC-0336K.
Hello, the tonnage on this unit is a 3 ton unit. Your model number tells you. The 036 is the tonnage. There are 12,000 btu's per ton, so 36 divided by 3 =12 or in this case 12,000 btu's.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jun 05, 2011 | Intertherm P3RC-036K Air Conditioner
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
Size
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Intertherm P3RA-036K Air Conditioner
Heating & Cooling Logo
206 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
