Question about General Heating & Cooling
Hello. My General airco (in Cyprus) works 10% normaly. 90% it start and stops after 10 seconds the it gives low air. But sometimes, today the first time, it works normaly, but when I switch it of and start after some hours again 10 seconds cold air. 10 seconds of. Remote control: Cool Fan control High Thermostat 16.
    Sergeant:
    Champion:
  • 230 Answers
Hello
If it was a general AC it must be running on a vapor - compression cycle, it must be the refrigerant (freon) that might have leaked and ran low causing the compressor to pump less refrigerant and is working on a low pressure compression which will make the system's cut - off ratio more often and in a much relatively shorter intervals. try checking the piping system for signs of leakage and immediately have it sealed from your local AC technician to have the refrigerant refilled after running a vacuum to **** all the air that accumulated in the pipes for efficient cooling. Hope this helps..
Take care!
Posted on Jul 07, 2010
  • klaascyprus Jul 08, 2010
    Ther was a technican and he has vulled up the system. He sad lichts on front are working and you have to buy a new one. After this when hy left I put the airco on and it was working perfct till I switsch off.
    When I put it on it was 10 sec. on. 10 sec. off. ventilator (compressor?) outside was no working.
    This problem I have with 2 airccos. There is no leakage in the system.
Why is my airco not cooling?
I believe that error code refers to a defective Indoor Coil Temperature Sensor (Thermistor); probably an "open" or "shorted" condition.
Jul 08, 2014 | Heating & Cooling
I have a strange situation going on in my house. When I turn on my airco frequently I get a nasty smell from the airco vents. Sometimes we have it running all day and it's fine (no smell at all) then at...
You should look in the air handler( Where the indoor blower is located) or in the plenum (where the duct system originate at the air handler) for any dead and rotting rats. Residential central air systems are sealed (uses circulated air only) and do not use outdoor air.
Aug 27, 2013 | Heating & Cooling
Airco seems to blow hot air most of the times, but cold occasionally
Seems like the blend door is intermittent,Like you said in some cases it works fine,Either the blend door is intermitent or the cycling switch is intermittent this is located on the filter drier when this pressure switch fails the A/C goes intermittent
Nov 23, 2012 | Cars & Trucks
90 CADILLAC HEATER BLOWS OUT COLD AIR
check the coolant level. If it is low the first thing to stop working is the heater.
If it is that low there is something leaking. A pressure check of the cooling system should help find the leak.
Feb 15, 2012 | Cars & Trucks
The airco system has completely stop working. The 4 position switch only work on number 4 and bring outside air (not airco) into the cabine
check fuses first - if ok.
check for refrigerant in A/C - if ok.
check switch and wires - it may be bad.
Apr 14, 2011 | 2001 Jeep Cherokee
Dear sir i have an A12AW1 art cool when i use the airco in the winter outsite temp -10 °C the airco somethime stops althow the roomtemperature is not reached. The airco is also outside...
Not sure the specs of 134. But, at 20 to 30 degrees Fahrenheit your heat pump is not going to be working very efficiently. Now, the ice on the coil is another story. Possibly your defrost is not working BUT, you don't have backup heat anyways. Yes, you should have a low pressure error code, I don't think it's a refrigerant issue.
May 26, 2017 | LG Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top General Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
