Question about LG 50PC1DRA 50 in. Plasma Television
TV turns itself off
When I turn on the TV within a couple of seconds I hear a pop and it turns off.
I can continue to turn it on and it goes off, but will eventually come on. When it does come on it takes about 5-10 minutes before the audio comes on.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.It seems to be an issue with the X, Y-main board however; control board should also be checked. As the sound is working fine so it means that power supply unit is functioning properly. Check for any bad/bulged capacitors on these boards. These boards are located on the right side of the unit and to check them you’ll have to open the back of the unit and then blow the dust off with a blow dryer. Once you have opened the back also check for any blown/bulged capacitors.All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 07, 2010
  • hduke83 Jul 08, 2010
    Ok. I assume you mean the right side looking at the back?
  • Rylee Smith
    Rylee Smith Jul 08, 2010
    Yup sorry, I should have made myself more clear. looking at the back the Y-sus board is located on the left side and the controller board is the one located next to the power supply unit on the left.
Once the VCR is turned on, it turns itself off.
If there is a mechanism fault on the VCR then the VCR will shut itself down. It sounds like the mechanism might be jammed, it's trying to move to the right position, when power is applied but can't so it stops. One thing that might be wrong is the mode switch might be faulty. This will cause all sorts of thing to happen, including putting on the timer record light even when none has been set.
Feb 16, 2014 | Panasonic PV-V4523S VHS VCR
Keeps reseting itself
Dude check your A/V or HDMI cables or whatever you use. HDMI cables can be tricky. Make sure that the different shades of color are matched up exactly. Ex: make sure light blue isn't plugged into the dark blue slot. it may not appear as if it matters but trust me it does.
Jan 01, 2014 | Sanyo Dp32640
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Turns off by itself
ther is technical error
Jul 11, 2009 | JVC LT-32P679 32 in. LCD TV
Problems with on/off button
Your Problem is the Hot transistor, it is short circuit. Causing the tv to go into protection. I f you say this is the second time the same problem tell the technician who works on the tv to replace all the caps on the collector of the Transistor and check the lopt transformer causing the HOT transisistor to fail thank you
May 16, 2009 | Philips 20PT91S 20" TV
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
LG 50PC1DRA 50 in. Plasma Television Logo
91 people viewed this question
Computer Repairing
Computer Repairing
