Question about Whirlpool ACD052MM Air Conditioner
Model#yacm052mmo what btu is this unit - Whirlpool ACD052MM Air Conditioner
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
What is the BTU of modelM6FQ10F2A
the btu rating will be on the same plate as the model number
if there is no btu rating but a kw rating then there are conversion tables to work it out
for example a 2kw unit is close to 9000 btu and a 8kw unit is around 32000btu
May 23, 2015 | Heating & Cooling
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
How do I find out how many "tons" my Carrier AC units are?
Look in the model number for numbers like 24, 30, 48, or 60....
They represent the BTU's in thousands of the unit....
The BTU's are 12,000 per ton...
in other words a 24000 BTU unit will be a 2 ton unit
heatman101
Jul 29, 2011 | Carrier Heating & Cooling
Need to know the size (btu) of a old ge unit model# BGTA9601A
This is a large unit going by the model number.12,000 BTU's per ton. It would be a 5 ton unit, or 60,000 BTU's.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Feb 18, 2011 | GE Heating & Cooling
What is the btu of this model.m7q08f2a.
Hi, to find out the tonnage of your unit in b. t. u.'s, look at the 08 in your model number. There are 12,000 btu's per ton of cooling. You have a window /wall unit, and according to the model # 08 is not a 1/2 ton or a 1 ton, but a 3/4 ton unit or 8,000 btu's if indeed this is the correct model number. Most units we come across are in btus as 06 which is 1/2 ton, 12,000 is 1 ton, 018 is 1 1/2 ton and on up with a properly matched indoor coil. Your unit is a package window unit, so both coils are equal.
Sincerely,
Shastalaker7
Nov 18, 2010 | Maytag M7Q08F2ACOM Air Conditioner
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Condensing unit
the 48 indicates 48,000 btu's. 12,000 btu's = 1 ton of cooling. this unit is a 4 ton condenser
Mar 15, 2008 | Heating & Cooling
Whirlpool ACD052MM Air Conditioner Logo
44 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
