Player worked great with one cd, but when added 10 more discs, it started playing then got code 1E3.
I presume you have a fault in your mechanism that is giving the wrong signals to the processor to hang up. Reset the changer if there is a preset present. Further you will need to remove the CD's from the changer and check if any of them are warped or damaged.Do repeat to load one cd and test, if this works then you are encoundering the fault when the changer loads, changing the trays. Look into the tray section for any change in the alignment.Clean off any dirt on the mechanism,look out for any broken flexible cords that moves for the motor drive. Also look out for any motor jamming of the load motor and the drive motor. You will need to look carefully for such faults to remove this error.
I hope this helps. Good day
