Question about Xerox Phaser 8550DX Laser Printer
Xerox 8550 Scanner Locked
How to unlock?
    President:
  • 2,072 Answers
8550or 8560???
The 8550 has no scanner.
Posted on Apr 18, 2008
My xerox work centre 4118 is locked How am I going to unlock it
Do you mean your "Scanner" is locked? Were the paper exits to the left of the opening there should be a sliding switch. I suggest that you should use a flashlight to locate it This is the locking mechanism that once toggled , it will unlock the scanner. Remember to turn-off the printers power before attempting this.
I hope this resolves your problem, Steve
Nov 06, 2015 | Xerox WorkCentre 4118x multifunction ( fax...
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
My Xerox 2400 Scanner is telling me it is locked but I have checked the switch and it is definitely in the unlocked position. I am also sing the correct power supply.I also uninstalled the software and...
Hello.
I am a Support Engineer with Xerox Scanners.
The scanner model that you have mentioned is very old. the description you have provided indicates that an internal component may have failed. I recommend calling our service department to discuss the replacement options available to you.
Please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Oct 08, 2012 | Xerox One Touch 2400 Flatbed Scanner
Display says Scanner locked
There is a green switch located under the scanner area of the machine. You will also see a diagram of locked and unlocked padlocks. Just slide the switch to the unlocked position. Hope this helps.
Apr 26, 2010 | Xerox WorkCentre M20i All-In-One Laser...
My workcentre pe220 printer's scanner is locked
my workcertre pe 220 scanner locked . how can i scanner unlocked?
Sep 03, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Iam trying to scan a document on my flatbed xerox 4800 but it keeps saying please unlock your scanner then it gives me time to do it but i dont know where to unlock it
you might have two program trying to use the scanner at the same time & the scanner is confused.Find out what programs you are using.Hint...even printer programs may use scanner drivers. 2nd.you MUST use the EXACT scanner driver for your scanner. Windows will see the scanner "locked out"
Jan 06, 2009 | Xerox One Touch 2400 Flatbed Scanner
At the lcd screen you can read this message: "ESCANNER DESABILITADO"what should I do?
The scanner probably got accidently locked. Turn the machine off, unlock the scanner, then turn back on.
Instructions on how to unlock the scanner are found here:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=143,E=0000000001181477675,K=8219,Sxi=11,Case=obj(349)
Dec 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Scanner locked. how to unlock
The scanner latch should be on the left side of the scanner.
You can try powering it off and on. Something is catching the scan head.
You should have a one year warranty on that product also if you need to call Xerox.
Feb 24, 2008 | Xerox WorkCentre 220 All-In-One Laser...
Xerox Phaser  8550DX Laser Printer Logo
76 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
