Question about Whirlpool LGV4634JQ Gas Dryer
How do I get at the valve coil when the dryer does not have a front access panel. Whirlpool LGR4634JQ2
  • 259 Answers
Ok, this dryer actually does have a front service panel, the entire front to be precise.
You will need to remove your lint screen first.
Now remove the two phillips head screws located at the lint screen inlet.
Next while standing in front of the dryer place a hand on the back of the control panel and pull the panel towards you. The entire top of the dryer should slide forward slightly and as it does use your fingertips to lift the top on the side you are pulling on at the front of the top where it meets the front panel. Now switch to the other side and repeat this until the entire front edge of the top is loose from the front panel.
Now lift the front of the top up and allow it to swing up like the hood on a car, let it lean against the wall.
Inside the front of the dryer you will see two screws that hold the top of the front panel to the sides of the unit. Remove these two screws and allow the top of the front panel to come forward slightly so that the felt support for the front of the drum is exposed on the top of the door opening. You may have to push the top of the drum towards the rear of the dryer.
Now pull up on first one side of the front panel and then the other side to disengage the lower portion of the front from the clips on the face of the side panels (they are like little hooks the front panel slips onto).
Once the front panel is loose you can usually swing it 90 degrees out to provide the access you need to your gas valve located in the bottom of the dryer (without disconnecting the door switch.
The drum should remain stationary as it will suspend on the two rear drum rollers while you work.
The gas valve coils are held to the gas valve by one steel cover plate that has two phillips head screws holding it to the valve.
Remove cover plate and wire connections, replace coils and reverse these instructions for re-assembly.
Good luck to you!
Posted on Jul 08, 2010
Whirlpool lg5771xww0
You don't. You can access the valves easily by dropping the base panel. You should however take the front panel off and remove the drum if you wish to do the job right. Yank out the filter. Remove the 2 screws holding the top to the filter chute. Grab the back of the dryer and raise up on the top in front to release it. The unplug the switch which goes to the door and remove some screws to get the panel off. Take 2 springs loose from bottom before removing the panel screws. Get the drum out and clean her up. This is important. To swap out the coils you will need a phillps head driver take 2 screws out lift coils up unplug coils and attach the new ones. Ain't no way to screw up the repair both coils are different and only go in one way. Here is my video:
Jun 17, 2013 | Whirlpool Dryers
Dryer will not heat
The problem with your dryer is bad coils on the gas valve. Replace the coils, Part number: AP2150379
and the dryer should be back to normal.
To get access to the coils you have to remove the front panel.
Good luck.
Jun 15, 2013 | Whirlpool GEW9200L Electric Dryer
I need to replace valve coils on Whirpool LGR3624JQ2 Gas Dryer. Problem is I don't know how to access the coil. How do I remove the front panel. Thanks NAL
Disconnect power to the dryer then pull the lint filter out and remove the screws near the opening.
Insert a putty knife blade or similar tool between the top panel and the front panel to release the clips securing the top panel to the top of the front panel on both sides as shown then rotate the top panel up to the rear of the dryer.
Disconnect the door switch wire harness then remove the front panel screws and lift the panel up and off the cabinet.
You now have access and view of the burner assembly where the gas valve coils are located.
Disconnect the wires from the coils and remove the screws from the bracket then lift the coils out. Slide the new coils in then secure it with the bracket and reconnect the wire harnesses.
Reinstall the front panel from the bottom then up and secure it to the cabinet. Rotate the top panel down back into position then push it against the top of the front panel until the securing clips engage and snap into place
Aug 22, 2010 | Whirlpool LGV4634JQ Gas Dryer
I have a Whirlpool LGR4634JQ2 gas dryer, I have checked all the venting from the dryer and nothing is blocked. However, the dryer still does not dry my clother properly. Sometime the heat comes on and...
This free video will walk you thru troubleshooting the problem. Could be a few different things Igniter,coils,heat sensor,thermal fuse, thermostat
Feb 26, 2010 | Whirlpool LGR4634J Gas Dryer
How to replace gas coil valves on Whirlpool LGR5636EQ3 Gas Dryer
DOES YOUR DRYER HAVE THE LINT SCREEN ON THE TOP? IF SO, REMOVE THAT AND TAKE TWO SCREWS OF(CARE NOT TO DROP IT INTO THE VENT). PULL THE TOP PANEL TOWARD YOU LITTLE BIT AND LIFT UP, THERE WILL BE TWO 5/16 SCREWS INSIDE FRONT PANEL, REMOVE AND UNPLUG THE LID SWITCH CONNECTOR, FRONT PANEL WILL COME OUT. THE GAS VALVES AND COILS ASSEMBLY WILL BE ON THE BOTTOM RIGHT. UNPLUG AND TAKE THE SCREWS OFF THE BRACKET AND REPLACE COILS. CHECK FOR CONTINUITY ON COILS, IT SHOULD READ 1.3 TO 1.9 OHMS. THE ONE WITH THREE TERMINAL, CHECK OHM FROM MIDDLE TERMINAL TO OUTSIDE TERMINALS.
BOYNISMO@YAHOO.COM 714-334-1998.
Aug 21, 2009 | Whirlpool LGR5636L Gas Dryer
IGNITER LIGHTS BUT NO FLAME
Hi, You will need to change the coils on top ogf the gas valve. If this is a Whirlpool model with rear panel access here is how: UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If this model is a front access model, just remove the lower front panle and the valve is on the right side
If I can assist you further, please let me know.
Thanks
Vic
Jul 15, 2009 | Dryers
Have a Whirlpool gas dryer, model #LGR4634JQ2, that will not heat anymore and has a rattling noise every now and then. Any ideas?
The rattling noise is maybe a sort of buzzing only more metallic? Sounds like the coils on the gas valve making it flutter. Causes are the coils and/or the ignitor.
Eric
Jun 07, 2009 | Whirlpool LGR7646E Dryer
Taking apart Whirlpool dryer
below the door the panel is held onto the frame with clips. Use a putty knife to get it out yer way.77d0e23.jpg
GAS DRYER INFO
Mar 02, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool dryer with no heat
Is the igniter glowing yellow? Look inside the pilot access hole and see if it lights up. If it lights up then goes off, it may be the thermal fuse. Once this blows, it has to be replaced. There are pictures all over the internet on the location of this part.
Good luck.
Apr 16, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
194 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
