Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I have a Sears evolv 3 gal air compressor that will not inflate a auto tire, even a partially de-flated tire. I let the pressure build to 100 psi and checked all fittings. Still wil not do it. Compressor is brand new out of the box.
    President:
  • Craftsman Master
  • 1,388 Answers
The evolv air compressor was primarily designed to power a very small nailer. The pressure regulator (knob in front) should be turned clockwise till it stops to attain full pressure. At this setting it should air your tire. If not you may have a defective regulator. There is a trick to get full pressure from your tank. Notice the small pressure safety valve on the side of the unit. You could remove this valve and install a fitting giving you two ports. One for the safety and other for a quick disconnect. This second port will give you access to tank pressure without going thru the pressure regulator. This mod is safe because you still have access to regulated pressure when you need it. Good luck
Posted on Jul 08, 2010
Will a air compressor that runs at 11.8 cfm at 90 psi run at 10 cfm at 100 psi?
if it is a 11cfm compressor then it produces 11.8 cfm of air regardless of the pressure
pressure has nothing to do with cfm but with the restriction to air flow
for example the tire inflator -air hawk- has a very small cfm but as the tire restrict the air flow the pressure builds up to set pressure on the gauge
so if you want 100psi from the 11.8cfm unit just adjust the pressure switch to shut off at 100psi
Cfm is only important when using air tools as a compressor that is not capable of maintaining the cfm thereby the pressure to run the tools is not a good idea
as an example
a sand blaster that uses 11.8 cfm at 100 psi will not work on your compressor
that unit will require a 20cfm compressor to run it peoperly
Sep 25, 2017 | Psi Air Tools & Compressors
My bostitch 6 gal compressor keeps running , and running , even goes into a higherpitch motor noise. can i check something ? or clean something to fix it ?
is it building up any pressure on the gauge
if the pressure recorded is around 40 psi or less , replace the failed poppet/reed valves in the compressor head
if it goes to 100 psi then replace the automatic controller for the motor
Jun 15, 2016 | Stanley Bostitch CAP200P-OF 6 Gallon...
Evolv 2 brad nailer no power
If you can check nailer on another compressor. If it works check your compressor, if not the nail gun is in need of repairs. Otherwise, reading the two guages on the compressor, check that the pressure in the tank is around 100psi and the regulated pressure is between 85 and 90psi. If not, regulated pressure is adjusted by the knob on the front of the housing. With a blowgun on the end of hose, connect the other end to the compressor. If you don't get any air the regulator may be broken and not letting air through. If you have air at the blowgun the problem may be with the nailer.
Apr 08, 2012 | Craftsman Air Tools & Compressors
My four-year old PC pancake compressor starts fine but only builds up 60 psi no matter how I adjust the pressure regulator. The compressor motor runs continuously. I checked for air leaks and can't find...
First take off the head on the air pump and check the reed valves on the valve plate. If they got hot and warped or cracked they'll work to a point then no more pressure can be built up. Next check the pistion ring and cylinder wall. If either is damaged you'll only get so much pressure build-up then it will leak past the piston.
Mar 07, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
MY COMPESSOR GAGE SHOWS 135 PSI AND 135 ON THE OUT PUT GAGE BUT I CAN,T INFLATE MY MOTORHOME TIRES TO THE REQUIRED 110#.DO I NEED A LARGER COMPRESSOR?I CAN,T FIND ANY LEAKS.
It is possible that the compressor psi as it is running drops below the tire psi creating a standoff. You must maintain air compressor psi over 110 to fill a tire to 110psi. Add air to your tire but stop when the compressor motor starts to run. When the motor stops then continue to add air until the compressor motor starts and again stop airing up the tire. Repeat as needed.
Dec 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Dec 08, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Oct 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
1,001 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
