Question about Electronics - Others
YAMAHA RX-V459. No power to the set except for incoming AC.
  • 17,129 Answers
You will need to trace from the point of the AC to the power unit. Use a multimeter to trace using the right range to check for the ac and the conversion to the DC side. Check to see if there is any fusible resistor failures to the main board. The fault can be numerous and you will arrive only with a systematic approach to the main board. Good day
Posted on Jul 14, 2010
What's difference between Sony str d615 an Yamaha rx v459
You should be able to download the user manuals on both of these units for free by just googling them and then compare the stats.
Larry
Aug 14, 2015 | Yamaha Audio Players & Recorders
Hi, I have a Yamaha RXV 459. Have speakers of DSE. The speakers are of 8 impedance. Was listening to music till 4 hrs ago. Switched off the whole unit from the power source. Returned and the unit is...
Disconnect the speaker one at a time, you may have a shorted voice coil, the message was indicated a short in the speaker wiring. If no joy then you may have burned out the power transistors.
May 16, 2017 | Yamaha RX-V459 Receiver
Hello i have a yamaha RX-v459, and i have an HDTV, can i connect my cable box to the yamaha and the yamaha to the TV and get HD? the Yamaha does not say HDTV, does that matter, or will i still get HD?
Yes, the cable box should/could be treated as any other digital audio device. The video could also be run directly to the TV as it doesn't actually improve from being routed to/through the Yamaha, does it?
The labeling on a given input is irrelevant (except for "PHONO", which is literal and exclusively for a turntable).
May 17, 2011 | Yamaha RX-V459 Receiver
Yamaha Cinema DSP Natural Sound System AV Receiver #RX-V459 was installed in 2005. It has never worked correctly. It sets on an open entertainment center. It has space all around, 2"on top and...
Are you saying the unit dies in 30 seconds at home but it works fine at Radio Shack?
Maybe you need to assess your power sourcing or any other condition that's unique.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 02, 2011 | Philips HTS-6500/37 System
I getting noise in yamaha rx-459 please help.
I used to get noise as well. It turned out to be that one of the cables to the speakers was loose. Try tightening the cable connections to the Yamaha and to the speakers.
Mar 01, 2011 | Yamaha RX-V459 Receiver
YAMAHA YDS-11 TO A RX-V459
Hi, as per yamaha site RX-V459 doesn't have the DOCK connector which is used by YDS-11 dock (or the bluetooth module). This is the only possibility to connect the YDS-11. YDS nor receiver don't have USB connector and they are not needed.
For example RX-V465 does have DOCK connector and supports YDS-11.
For your receiver, you can use only analog audio cable with your iPod.
Dec 17, 2009 | Yamaha RX-V459 Receiver
Vocals missing while playing with 2 speakers
Go to the amp "Basic Setup" and alter basic setup according to
- the size of the room (details in the manual)
- alter the no. of channels e.g. if you have only 2 front speakers, change the channels to 2.1 (.1 for the subwoof)
- Once the setup is changed, the amp pumps in sound according to the set up
All the best
Apr 25, 2008 | Yamaha RX-V459 Receiver
Electronics - Others Logo
338 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
